Black-Pearl |
September 5, 2013 03:32 |
Heattransfer between two fluids with chtMultiRegionFoam
Hello Foamers,
I try to simulate the heattransfer from air to aluminium melt.
Because both regions are fluids.
My problem is, that the temperature of the hot air rises to much and the solver crashes.
(heater = hot air)
Adding to radiations
Selecting radiationModel none
Adding fvOptions
No finite volume options present
Region: luft_1 Courant Number mean: 5.6643852e-06 max: 5.9790732e-06
Region: luft_2 Courant Number mean: 5.5804684e-06 max: 5.9790732e-06
Region: alu Courant Number mean: 4.2805601e-06 max: 5.9790732e-06
Region: heater Courant Number mean: 3.3681765e-06 max: 3.4843206e-06
Region: deckel Diffusion Number mean: 2.6216803e-16 max: 4.3940875e-16
Region: wall Diffusion Number mean: 3.6396234e-16 max: 5.8570489e-16
Region: handdeckel Diffusion Number mean: 4.5676729e-08 max: 6.8332266e-08
Region: zwischenwand Diffusion Number mean: 2.8232898e-15 max: 5.1249199e-15
Region: zwischenwand_2 Diffusion Number mean: 2.8232898e-15 max: 5.1249199e-15
deltaT = 1.1111111
Region: luft_1 Courant Number mean: 0.62937613 max: 0.66434147
Region: luft_2 Courant Number mean: 0.62005204 max: 0.66434147
Region: alu Courant Number mean: 0.47561779 max: 0.66434147
Region: heater Courant Number mean: 0.37424184 max: 0.38714673
Region: deckel Diffusion Number mean: 2.9129781e-11 max: 4.8823194e-11
Region: wall Diffusion Number mean: 4.044026e-11 max: 6.5078321e-11
Region: handdeckel Diffusion Number mean: 0.0050751921 max: 0.007592474
Region: zwischenwand Diffusion Number mean: 3.1369887e-10 max: 5.6943555e-10
Region: zwischenwand_2 Diffusion Number mean: 3.1369887e-10 max: 5.6943555e-10
deltaT = 1.1111111
Time = 1.11111
Solving for fluid region luft_1
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.737572e-08, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 6.5281948e-08, No Iterations 4
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 2.9039288e-08, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.2020789e-09, No Iterations 5
Min/max T:300.24666 993.14169
GAMG: Solving for p_rgh, Initial residual = 0.56298287, Final residual = 0.0032868215, No Iterations 3
time step continuity errors (luft_1): sum local = 2.3892722, global = 1.4963068e-06, cumulative = 1.4963068e-06
GAMG: Solving for p_rgh, Initial residual = 0.35860088, Final residual = 4.732492e-08, No Iterations 16
time step continuity errors (luft_1): sum local = 4.2957906e-05, global = 5.4348928e-09, cumulative = 1.5017417e-06
Solving for fluid region luft_2
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.0511042e-09, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.6199339e-08, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.1357105e-08, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 5.8394195e-10, No Iterations 4
Min/max T:287.5932 973.05287
GAMG: Solving for p_rgh, Initial residual = 0.71514628, Final residual = 0.0044174618, No Iterations 4
time step continuity errors (luft_2): sum local = 4.6086846, global = 0.047848992, cumulative = 0.047848992
GAMG: Solving for p_rgh, Initial residual = 0.53521726, Final residual = 8.5766589e-08, No Iterations 19
time step continuity errors (luft_2): sum local = 0.00011735656, global = -5.2057022e-08, cumulative = 0.04784894
Solving for fluid region alu
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 5.1476407e-09, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.6190324e-09, No Iterations 4
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 2.6978468e-09, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 1.1888477e-09, No Iterations 7
Min/max T:971.4221 979.4297
GAMG: Solving for p_rgh, Initial residual = 0.96087844, Final residual = 0.0079759011, No Iterations 4
time step continuity errors (alu): sum local = 1.3946648, global = -9.5125042e-16, cumulative = -9.5125042e-16
GAMG: Solving for p_rgh, Initial residual = 0.91174318, Final residual = 4.1837808e-08, No Iterations 13
time step continuity errors (alu): sum local = 6.1779247e-06, global = 1.2161781e-16, cumulative = -8.2963261e-16
Solving for fluid region heater
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 5.355734e-08, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 5.7924232e-09, No Iterations 6
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.6373432e-08, No Iterations 6
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 5.0288202e-08, No Iterations 7
Min/max T:-4.9069669e+09 8.7303124e+09
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 void Foam::divide<Foam::fvsPatchField>(Foam::FieldField <Foam::fvsPatchField, double>&, Foam::FieldField<Foam::fvsPatchField, double> const&, Foam::FieldField<Foam::fvsPatchField, double> const&) at ??:?
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField< double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:?
#6 Foam::fv::EulerDdtScheme<Foam::Vector<double> >::fvcDdtPhiCorr(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped
My boundary conditions for the temperature:
heater/Hot-air
T
dimensions [0 0 0 1 0 0 0];
internalField uniform 1173.15;
boundaryField
heater_to_wall
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value uniform 1173.15;
neighbourFieldName T;
kappa fluidThermo;
kappaName none;
heater_to_deckel
kappa fluidThermo;
kappaName none;
heater_to_alu
kappa fluidThermo;
kappaName none;
for the aluminium melt (=alu)
T
internalField uniform 973.15;
boundaryField
alu_to_wall
value uniform 973.15;
kappa fluidThermo;
kappaName none;
alu_to_zwischenwand_2
kappa fluidThermo;
kappaName none;
alu_to_zwischenwand
kappa fluidThermo;
kappaName none;
alu_to_luft_2
kappa fluidThermo;
kappaName none;
alu_to_luft_1
kappa fluidThermo;
kappaName none;
alu_to_heater
kappa fluidThermo;
kappaName none;
the thermophysical Properties
for the heater/Hot air
thermoType
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1170;
Hf 0; //2.554e+06;
transport
mu 1.8e-05;
Pr 0.7395;
for the aluminium melt:
thermoType
type heRhoThermo;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
mixture
specie
nMoles 1;
molWeight 26.98;
equationOfState
rho 2400;
thermodynamics
Cp 1000;
Hf 0;
transport
mu 0.03552;
Pr 0.18;
I could not find my problem. Have everyone an idea???
Thank you very much.
Best regards,
Ceci
