Openfoam Turbulent Car Simulation
Old   July 5, 2021, 15:50
Default Openfoam Turbulent Car Simulation
Megan
meganrw is on a distinguished road
Hi, I am trying to run a turbulent car simulation where a person coughs for 0.5 seconds with a wind coming in through the window. My friend ran the simulation in ansys and sent me the mesh file. However I keep getting errors - I get the error
" #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:? "
which I know is usually a mesh or boundary condition related error but I just can't figure out what the issue actually is. The mesh should be okay as the simulation runs in ansys so the issue is probably in the boundary. Thanks in advance !
p
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet_wind
type zeroGradient;
outlet_wind
type fixedValue;
value 0;
inlet_mouth_front
type zeroGradient;
inlet_mouth_rear
type zeroGradient;
wall_left
type zeroGradient;
wall_right
type zeroGradient;
wall_bottom
type zeroGradient;
wall_top
type zeroGradient;
wall_front
type zeroGradient;
wall_rear
type zeroGradient;
wall_window_front_right_1
type zeroGradient;
wall_window_front_right_2
type zeroGradient;
wall_window_front_left_1
type zeroGradient;
wall_window_front_left_2
type zeroGradient;
wall_window_rear_right_1
type zeroGradient;
wall_window_rear_right_2
type zeroGradient;
wall_window_rear_left_1
type zeroGradient;
wall_window_rear_left_2
type zeroGradient;
wall_tunnel
type zeroGradient;
wall_head
type zeroGradient;
wall_seat_right
type zeroGradient;
wall_seat_left
type zeroGradient;
wall_trunk
type zeroGradient;
wall_seat_rear
type zeroGradient;
U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet_wind
type fixedValue;
value uniform (15 0 0);
outlet_wind
type inletOutlet;
inletValue uniform (0 0 0);
inlet_mouth_front
type uniformFixedValue;
uniformValue table
( 0 (0 10 0))
(0.5 (0 10 0 ))
(0.5001 (0 0 0 ))
inlet_mouth_rear
type noSlip;
wall_left
type noSlip;
wall_right
type noSlip;
wall_bottom
type noSlip;
wall_top
type noSlip;
wall_front
type noSlip;
wall_rear
type noSlip;
type noSlip;
type noSlip;
type noSlip;
type noSlip;
type noSlip;
type noSlip;
type noSlip;
type noSlip;
wall_tunnel
type noSlip;
wall_head
type noSlip;
wall_seat_right
type noSlip;
wall_seat_left
type noSlip;
wall_trunk
type noSlip;
wall_seat_rear
type noSlip;
nut
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet_wind
type calculated;
value uniform 0;
outlet_wind
type calculated;
value uniform 0;
inlet_mouth_front
type calculated;
value uniform 0;
inlet_mouth_rear
type nutkWallFunction;
value uniform 0;
wall_left
value uniform 0;
wall_right
value uniform 0;
wall_bottom
value uniform 0;
wall_top
value uniform 0;
wall_front
value uniform 0;
wall_rear
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
value uniform 0;
wall_tunnel
value uniform 0;
wall_head
value uniform 0;
wall_seat_right
value uniform 0;
wall_seat_left
value uniform 0;
wall_trunk
value uniform 0;
wall_seat_rear
value uniform 0;
k
internalField uniform 0.375;
boundaryField
inlet_wind
type fixedValue;
value uniform 0.375;
outlet_wind
type zeroGradient;
inlet_mouth_front
type fixedValue;
inlet_mouth_rear
type kqRWallFunction;
value uniform 0.00375;
wall_left
wall_right
wall_bottom
wall_top
wall_front
wall_rear
wall_tunnel
wall_head
wall_seat_right
wall_seat_left
wall_trunk
wall_seat_rear
omega
dimensions [0 0 -1 0 0 0 0];
internalField uniform 440.15;
boundaryField
inlet_wind
type fixedValue;
value $internalField;
outlet_wind
type zeroGradient;
inlet_mouth_front
type fixedValue;
inlet_mouth_rear
type omegaWallFunction;
value uniform 22.4;
wall_left
value uniform 22.4;
wall_right
value uniform 22.4;
wall_bottom
value uniform 22.4;
wall_top
value uniform 22.4;
wall_front
value uniform 22.4;
wall_rear
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
value uniform 22.4;
wall_tunnel
value uniform 22.4;
wall_head
value uniform 22.4;
wall_seat_right
value uniform 22.4;
wall_seat_left
value uniform 22.4;
wall_trunk
value uniform 22.4;
wall_seat_rear
value uniform 22.4;
epsilon
dimensions [0 2 -3 0 0 0 0];
internalField uniform 14.855;
boundaryField
inlet_wind
type fixedValue;
value uniform 14.855;
outlet_wind
type zeroGradient;
value uniform 0;
inlet_mouth_front
type fixedValue;
inlet_mouth_rear
type epsilonWallFunction;
value uniform 0.00754;
wall_left
wall_right
wall_bottom
wall_top
wall_front
wall_rear
wall_tunnel
wall_head
wall_seat_right
wall_seat_left
wall_trunk
wall_seat_rear
SYSTEM
controlDict
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 10;
deltaT 0.0005;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat binary;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwindV grad(U);
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fvSolution
solvers
p
solver GAMG;
smoother GaussSeidel;
tolerance 1e-7;
relTol 0.01;
Phi
$p;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
equations
U 0.9;
k 0.7;
omega 0.7;
cache
grad(U);
meganrw is offline   Reply With Quote
car, openfoam, sigfpe, simplefoam, turbulent
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Some questions about making a car racing simulation yossir4 FLUENT 0 November 11, 2013 01:58
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
