The first one is the one that is implemented in OpenFOAM, as you can easily confirm from alphaEqn.H.
The second one does not have a meaning from a simulation point of view, as there is only one U in the simulations. You don't keep track of both liquid and gas velocity, as you would do in twoPhaseEulerFoam. However, if you would use indicator functions for that set of equation, you will eventually find U_c=U_l-U_g. Also, be aware that this is not a counter-gradient term, but more of a convective like term, with the same purpose in the end. |
