Scripts to manage OpenFOAM cases
Like Tree8Likes
  • 8 Post By Logan Page
Old   September 30, 2013, 15:27
Default Scripts to manage OpenFOAM cases
Ye Zhang
kiddmax is on a distinguished road
Dear foamers,
I am wondering how to write a script to manage OpenFOAM cases. Since I need to simulate 2D airfoil flow at different angle of attacks. Everytime I have to copy the case files and change the velocity and lift and drag direction. This method is time consuming and use a lot of disk. I know that using a script to mange the case and change the boundary condition is possible, anyone can give me some hints?
Best regards,
Ye
kiddmax is offline   Reply With Quote
Old   September 30, 2013, 21:24
simon-2 is on a distinguished road
you can use a custom dict, containing AoA in your case.
in your files 0/U etc include your dict und use variables depending on the entries in your dict.
for example
Ux #calc "$myVelocity*cos($myAoA)";
fixedValue ($Ux $Uy $Uz)
referring to myVelocity and myAoA in your dict.
this way, you only have to change the myAoA entry in a single dict to modify the case.
Further, you can also use a shellscript to do the following steps for a whole list of prepared dict-files:
copy dict_#i into the case,
./Allrun case,
make directory anywhere/#i
copy relevant output to anywhere/#i,
./Allclean case
there might be more elegant ways, but it should work
simon-2 is offline   Reply With Quote
Old   October 1, 2013, 10:08
Logan Page
Logan Page is on a distinguished road
I had a similar requirement, for which I created Python scripts (using some of pyFoam's functionality) to manage my case files and the automation of multiple CFD simulations.
Logan Page is offline   Reply With Quote
Old   October 3, 2013, 17:50
Ye Zhang
Thank you Logan!
Cause I am quite new to OpenFOAM. It will be better if you can describe it more detail.
Best regards,
Ye
Old   October 4, 2013, 06:50
Logan Page
Hi
I effectively set up code as described in the attached images.
The OpenFoam utilities and solvers where called (run) through the use of pyFoam. http://openfoamwiki.net/index.php/Contrib_PyFoam
In my case the mesh file was also scripted / generated in Python and then used in blockMesh, but you can easily use another meshing program like gmsh coupled to Python.
The general process I followed is:
  1. setup a base case directory and files (e.g. AOA = 0), that has the 0, constant and system files needed for your simulations
  2. create a new directory for a new sim (e.g. AOA = 3) [I used Python to manage my directories based on the value for a given variable, e.g. `os.makedirs(some_path/AOA_03)`]
  3. I used pyFoam to clone the base case files into the new directory `pyFoam.SolutionDirectory.cloneCase`
  4. create the mesh / meshFile -- there are multiple options here depending on what meshing program you are using, for example:
    • gmsh
      • create an initial parameterized .geo file
      • there are probably ways to improve this, but I then copied the .geo file text to Python and used Python to change the parameter values and write a new .geo file to the new directory
      • I can't remember if I used `pyFoam.UtilityRunner` or a Python subprocess to then run gmsh with new the .geo file
      • you can probably also play around with the `-merge` option when calling gmsh and only use Python to write a file with the parameters in it (haven't tried this)
      • then I used `pyFoam.UtilityRunner` to run `gmshToFoam'
      • It's been awhile since I've done this, but if I recall correctly there may have been issues with boundary types after `gmshToFoam` and you may need to also update the types in the constant/polyMesh/boundary
    • blockMeshDict with m4
    • create the blockMeshDict file in Python
      • this requires the most work and I definitely don't have an optimal process / solution for this, but it is doable.
  5. I then used `pyFoam.UtilityRunner` to run`blockMesh`
  6. if I had any boundary conditions or fluid properties that needs changing, I used `pyFoam.ParsedParameterFile` to edit / change values in the specific files
  7. then finally I used one the the `pyFoam` runners to call the OpenFoam solver, e.g. `pyFoam.PlotRunner` / `pyFoam.SteadyRunner`
  8. I then used Python to extract the results I wanted from the simulation and pop the results for each simulation into a central log file.
Here are the two Python files I used that may help you on your way.
SolveFoam.txt
RunFoamS0Solution1.txt
Old   October 4, 2013, 06:54
Olivier
olivierG is on a distinguished road
hello,
Like Logan say, take a look at pyFoam
There is a full section about manipulating case.
You can also change boundary with the changeDictionary commande, usin a "changeDictionnaryDict" file.
regards,
olivier
olivierG is offline   Reply With Quote
Old   July 17, 2020, 06:09
liwenpeng
liwenpeng is on a distinguished road
Originally Posted by olivierG View Post
hello,
regards,
olivier
Do I need to install Python on Linux
liwenpeng is offline   Reply With Quote
Old   July 17, 2020, 06:14
Assistant Moderator
Bernhard Gschaider
It's hard to find a Linux distribution that hasn't got Python installed
But if you want to use PyFoam: yes. Python is necessary
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 17, 2020, 06:18
liwenpeng
My computer is a Windows system. In order to run openfoam, I have installed Ubuntu Linux. If I want to use pyform, what should I do?. Do I install Python on windows or Ubuntu Linux。
thanks
Old   July 17, 2020, 11:38
benoit paillard
bennn is on a distinguished road
If you want your life to be easy and enjoyable, I'd suggest sticking to a linux distribution and never use Windows for Openfoam simulations.
bennn is offline   Reply With Quote
Old   July 17, 2020, 23:41
liwenpeng
thanks for your advice
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 17:52
Is OpenFOAM tutorial cases valid? j-avdeev OpenFOAM Running, Solving & CFD 3 September 19, 2012 16:45
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 06:43
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
Manage openfoam solver project in KDevelop probably the last linker error any suggestion is welcome lakeat OpenFOAM Installation 0 July 7, 2007 11:01
