k-Omega SST with curvature correction
Dear all,
Does anybody know how to enable the curvature correction in the k Omega SST model? I am using OpenFOAM 2.1. Thank you best regards Luca |
Bump...does anybody know?
I'm not aware of any rotation or curvature sensitized kOmegaSST in OpenFOAM.
Very glad to discover I'm wrong :) Can you please provide more details on what you actually mean? |
Surfing internet I have found out that someone has already developed a modified k-Omega SST library with the curvature correction term: https://github.com/Unsupported-Contr...x/pull/7/files (however now it seems that the website is down). |
Hi LM4112,
"https://github.com/Unsupported-Contr...x/pull/7/files (however now it seems that the website is down)". What u mean? I tried the website and works fine. I guess you can find the code that you are looking for there. Regards, |
hi Luca,
have you tried the kOmegaSST with rotation correction? How was it? |
Any news about the implemented version of the kOmegaSST with curvature correction?
It looks that the web address of the code is down! Any one here to share the code?
I have updated the previous version (https://github.com/cvillescas/TkOmegaSSTCC) valid for OF 2 to the new template based formulation.
I have tested it in OF 5 https://github.com/ancolli/kOmegaSSTCC |
Dear Ancolli, I know this is sort of an old thread, but I have some confusion reading your code that I hope you would help me clearify. In the beginning, you define the strain rate tensor S and vorticity tensor \Omega as tSymm and tSkew, respectively: Code:
tmp<volTensorField> tgradU = fvc::grad(U); Code:
Then you continue with: Code:
volScalarField w The same occurs later with rTilda as you defined it based on w2, which is also an unknown variable to me, and not how it is defined in the paper based on \Omega. I would appreciate it very much if you take the time to clearify this to me! Thanks in advance! Regards, Mazen |
I do not really remember the details. But, with regards to your first question. Effectively, I have used the code for a non rotating reference frame. Thus, in your case u should include it.*With regards to w and the definition of rstar. I only updated the old code (https://github.com/cvillescas/TkOmegaSSTCC) to newer versions of OpenFOAM. U must contact the original developers. Regards |
