rhoSimpleFoam convergence problem - bounding omega
I am new to OpenFOAM. I am trying to simulate flow through a valve with one inlet and one outlet. I want to look at the outlet mass flow rate and then calculate Cd value for the valve. The problem is I am getting bounding omega error no matter what I change. The values are large negative numbers - four digit negative numbers. I am using rhoSimpleFoam Here are the files k: dimensions [0 2 -2 0 0 0 0]; internalField uniform 6.67; boundaryField { egr_valve_inlet { type fixedValue; value uniform 6.67; } egr_valve_outlet { type zeroGradient; } egr_valve_wall { type compressible::kqRWallFunction; value uniform 6.67; } } Omega: dimensions [0 0 -1 0 0 0 0]; internalField uniform 645.659; boundaryField { egr_valve_inlet { type fixedValue; value uniform 645.659; } egr_valve_outlet { type zeroGradient; } egr_valve_wall { type compressible::omegaWallFunction; value uniform 645.659; } } U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { egr_valve_inlet { type pressureInletVelocity; value uniform (0 0 0); } egr_valve_outlet { type zeroGradient; } egr_valve_wall { type fixedValue; value uniform (0 0 0); } } p: dimensions [1 -1 -2 0 0 0 0]; internalField uniform 95600; boundaryField { egr_valve_inlet { type totalPressure; U U; phi phi; rho rho; psi none; gamma 1.4; p0 uniform 95600; } egr_valve_outlet { type fixedValue; value uniform 94600; } egr_valve_wall { type zeroGradient; } } T: dimensions [0 0 0 1 0 0 0]; internalField uniform 298; boundaryField { egr_valve_inlet { type fixedValue; value uniform 487.924; } egr_valve_outlet { type zeroGradient; } egr_valve_wall { type fixedValue; value uniform 298; } } fvSchemes: ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { div(phi,U) bounded Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,Ekp) bounded Gauss upwind; } laplacianSchemes { laplacian(muEff,U) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } fvSolution: solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; cacheAgglomeration off; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0.1; } e { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0.1; } "(k|omega)" { $U; tolerance 1e-07; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin rhoMin [ 1 -3 0 0 0 ] 0.5; rhoMax rhoMax [ 1 -3 0 0 0 ] 1.5; residualControl { p 1e-4; U 1e-4; e 1e-4; // possibly check turbulence fields "(k|omega)" 1e-4; } } relaxationFactors { fields { p 0.3; rho 0.05; } equations { U 0.7; "(k|omega)" 0.7; e 0.5; } } I change tolerances and solvers and i get different answers everytime. The temperature plots are very weird and even if the solution says it is converged, the feilds are changing as i change the time step. Please help me solve this problem. :confused::confused: |
I would suggest trying simpler solution and then U should go for complex problem as you are a beginner. I think you should go for a mesh convergence study and please have some reference to see whether your solution is correct or not. LOL just noticed that this was asked in 2013. |
