August 12, 2009, 09:34 |
kinematicCloud initialization
Alberto Passalacqua
Rep Power: 36 |
I'm working with the lagrangian solvers, and I would need to initialize a closed domain with a uniform particle concentration field. I checked the injection models, but the only possibility I found is to manually specify the particle position in a file, which is kind of hard if the domain is not elementary and if the number of particles is high. Any suggestion? Thanks
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 15, 2013, 09:56 |
Re: KinematicCloud injection
Boxiong
Rep Power: 15 |
Hi, Alberto,
I also need to work with KinematicCloud in OpenFOAM 2.0, and it's been a long time since you initiated the thread. Have you got a satisfactory answer or solution to the problom? Chuck |
Initialization problem when using Axisymmetry BC | Eduardo | FLUENT | 0 | August 4, 2008 09:23 |
Initialization | a student | Siemens | 2 | May 19, 2006 12:55 |
compressor initialization | paglia | FLUENT | 0 | February 1, 2006 15:14 |
Mesh Initialization | shakked | Main CFD Forum | 2 | August 7, 2004 22:50 |
Mesh Initialization | shakked | FLUENT | 1 | August 5, 2004 09:41 |
