RNG k-epsilon model implementation
Like Tree1Likes
  • 1 Post By vkrastev
Old   July 27, 2011, 08:52
Default RNG k-epsilon model implementation
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I was wondering why the implementation of the RNG k-epsilon model in OpenFOAM looks so much different from the implementation of the standard k-epsilon model? Even the k-equation looks different, even though that one should be the same.
k-equation standard k-eps:
    tmp<fvScalarMatrix> kEqn
        fvm::ddt(k_)
      + fvm::div(phi_, k_)
      - fvm::Sp(fvc::div(phi_), k_) // missing from the k-equation of RNG
      - fvm::laplacian(DkEff(), k_)
        G
      - fvm::Sp(epsilon_/k_, k_)
k-equation RNG k-eps
        fvm::ddt(k_)
        G
The - fvm::Sp(fvc::div(phi_), k_) term is missing. The same is true in the epsilon equation, where instead of the C_eps2 constant the C_eps1 constant is changed, but also not according to literature
eps-equation RNG
    // Dissipation equation
    tmp<fvScalarMatrix> epsEqn
        fvm::ddt(epsilon_)
      + fvm::div(phi_, epsilon_)
      - fvm::laplacian(DepsilonEff(), epsilon_)
    // I expect another term here
        (C1_ - R)*G*epsilon_/k_  // why is the term R, which is part of the changed C_eps2 constant subtracted from C_eps1
    //- fvm::SuSp(R*G/k_, epsilon_)
      - fvm::Sp(C2_*epsilon_/k_, epsilon_)  // C2 is a constant here, even though it should be a function of the strain-rate tensor
~roman
romant is offline   Reply With Quote
Old   November 23, 2011, 09:19
Vesselin Krastev
vkrastev is on a distinguished road
Originally Posted by romant View Post
Hej,
        fvm::ddt(k_)
        G
        fvm::ddt(k_)
        G
eps-equation RNG
        fvm::ddt(epsilon_)
The implementation is perfectly consistent with the literature (see for instance "Analysis of an RNG based turbulence model for separated flows", C. G. Speziale and S. Thangam, Int. J. Engng Sci., Vol 30, no 10, pp 1379-1388, 1992). Concerning the missing terms with respect to, for instance, the standard k-epsilon model, though they should not have a significant relevance in an incompressible flow solution (fvc::div(phi) would be exactly equal to zero if the discretized momentum and pressure-correction equations were solved exactly at the current iteration, while using a finite precision it would be simply very very small), to me is also quite a mystery why they are included in some models and they aren't in others...
Best Regards
V.
vsammartano likes this.
vkrastev is offline   Reply With Quote
Old   June 20, 2018, 08:33
Hosein
einstein_zee is on a distinguished road
Hej,
        fvm::ddt(k_)
        G
        fvm::ddt(k_)
        G
eps-equation RNG
        fvm::ddt(epsilon_)
Hi Roman,
Could you find the reason why the OF version of equations are not similar to the ones of Yakhot et al.
einstein_zee is offline   Reply With Quote
rngkepsilon, turbulence model
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
problems with a DES (k-epsilon model) implementation sven82 OpenFOAM Running, Solving & CFD 16 November 28, 2017 06:17
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
RNG (renormalized group) or RM(realizable model) based on K-e heidar FLUENT 0 April 17, 2010 04:21
How to define Epsilon in RSM model? David FLUENT 0 March 17, 2004 09:39
