ouflow boundary problem
Old   October 9, 2013, 11:49
Default ouflow boundary problem
izna O'connor
izna is on a distinguished road
Hi..
I am simulating flow around some shapes, in 2D.
I used simpleFoam and PCG solver with K-epsilon . My aim is to put my 3 boundaries as Outflow.. and my 1 bounday as inlet..
Hence i use the Zero gradient bC.. But alas i obtain the following results..
Can anyone please advice me on which BC to use and how please..
izna is offline   Reply With Quote
Old   October 14, 2013, 08:18
Artem Shaklein
ARTem is on a distinguished road
Hello, izna O'connor.
Is your flow supersonic? If not, you should specify pressure or velocity at outlet (i.e. not zeroGrad for all variables).
Are you sure that substance strictly flows out through this 3 boundaries (by physics, not by mathematics)? If so, you can cast restriction by using following BC "type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0);".
ARTem is offline   Reply With Quote
Old   October 14, 2013, 08:30
izna O'connor
hello ARtem..
can you please check those posts? http://www.cfd-online.com/Forums/ope...tml#post456727
I cannt run it with simpleFooam and its not supersonic..
Old   November 2, 2013, 06:00
Yao Lu
shuoxue is on a distinguished road
Originally Posted by izna View Post
Hi..
Hi, izna!
Have you found out the way to simulate outflow BC with openfoam?
I'm solving a flow around cylinder case with interFoam. I have tried freestream and freestreamPressure BC in U and p files. However, the drag coefficient doesn't match the values announced in papers.
shuoxue is offline   Reply With Quote
boundary condition, simplefoam convergence
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 09:28
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Outflow boundary condition for convecction-difussion problem. juanelo14 Main CFD Forum 0 September 27, 2012 00:20
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 01:54
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
