November 8, 2013, 07:39 |
Wrong results in OpenFoam parallel runs
Visakh
Hello everyone,
I am runing 3D incompressible cases with simpleFoam as well as porousSimpleFoam in OpenFoam 2.1.1. I have noticed that when i start a parallel run from scratch (from time 0), it gives me wrong results and some times the simulation blows off. But when I start the parallel run after a few (say 50) time steps in seriala and switch on to parallel, it gives me reasonable reults. I am using scotch decomposition method and the domain is relatively bulky. Does the error increase with number of processors I am using? I heard there is some problem with parallelization in OpenFoam 2.1.1. Is it true? And finally, what is the diference between scotch and metis decomposition methods? |
November 9, 2013, 13:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Visakh,
It doesn't matter as much the version of OpenFOAM you are using, because any version can lead to a crash, if certain details are not taken into account when running in parallel, as listed here: http://www.cfd-online.com/Forums/ope...tml#post324934 - post #28 provides a list of known reasons why a run might not go well in parallel. Best regards, Bruno
error, parallel computing, parallel decomposition, scotch, wrong results |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
Running in parallel with a machine that doesn't have OpenFOAM | aujamal20 | OpenFOAM Running, Solving & CFD | 1 | September 14, 2013 10:08 |
OpenFoam Parallel running | shipman | OpenFOAM Running, Solving & CFD | 3 | August 17, 2013 10:50 |
OpenFOAM doesn't run in parallel | callumso | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 12:17 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
