ERROR : Floating point exception (core dumped)
Like Tree1Likes
  • 1 Post By sam.ho
Old   November 14, 2013, 01:27
Exclamation ERROR : Floating point exception (core dumped)
sam.ho is on a distinguished road
Hi
I am simulating a overflow valve with simple foam.
Velocity of fluid is 0.27 m/s
Dynamic Viscosity = 8.26 X 10^-6 Kg/m.s
Density = 830 Kg / m3
Radius of the inlet = 6.9 mm
I am getting the error which is attached and also looked in to many discussions on this topic but not able to fix this issue..
Please help me
File Type: jpg Screenshot from 2013-11-14 11:03:45.jpg (87.6 KB, 29 views)
sam.ho is offline   Reply With Quote
Old   November 14, 2013, 04:33
Martin Beeger
Ralinus is on a distinguished road
Your viscosity maybe too small. Try a bigger value and see if this fixes your error.
This shown error is a preconditioner failure, if increasing viscosity does not help try tuning preconditioner parameters.
Ralinus is offline   Reply With Quote
Old   November 14, 2013, 05:00
Post simpleFOAM SOLVER
[FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 2;
pRefCell 101;
pRefCell 58;
pRefCell 767;
pRefCell 527;
pRefValue 0;
residualControl
p 1e-2;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
THis is the solver file... Please check let me know anything need to be changed ?
Old   November 14, 2013, 05:40
Martin Beeger
Try setting the dynamic viscosity to a bigger value (like 8e-3 instead of 8e-6). I don't actually know which changes you have to make to get you preconditioner able to handle these viscosities.
Old   November 14, 2013, 06:03
I should not change dynamic viscosity as these are defined values for my case ...
Alisa_W likes this.
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) ArianeJasmin OpenFOAM Programming & Development 1 April 4, 2012 14:11
Exception en point flottant thomasse OpenFOAM 3 August 9, 2011 00:50
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
Flouting point exception twoPhaseEulerFoam - I set delta t cristina87 OpenFOAM 1 May 26, 2011 15:35
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
