RhoCentralFoam: supersonic flat plate (bad temperature) |
November 18, 2013, 00:06 |
Hi, I'm trying to validate rhoCentralFoam by solving the supersonic flat plate. I impose zero gradient for temperature at the wall (adiabatic wall). In agreement with theory, wall temperature for r=1 (recovery factor) should be the free stream total temperature. I solve the case for Ma=2.0 thus the wall temperature should be 518.67 K, but predicted wall temperature with rhoCentralFoam are 391.49K (%error 24.5). Any suggestion is welcome.
I'm using vanLeer function for reconstruction and for gradients least squares. Thanks in advance
Felipe G |
January 12, 2016, 19:42 |
Hilbert
Rep Power: 10 |
Hi Felipe,
I understand that this is an old thread, but I was wondering if you found a solution? I am currently facing the same problem. I have a reference case from CFX. The rhoCentralFoam solution perfectly represents the pressure, but the temperature is under predicted. Cheers |
rhocentralfoam, stagnation temperature, supersonic flatplate |
rhoCentralFoam flat plate boundary layer issues | laurensvd | OpenFOAM Running, Solving & CFD | 6 | September 13, 2013 03:10 |
flow over a plat and study of temperature distribution in plate and flow | Sufyan | FLUENT | 0 | October 16, 2012 03:38 |
cavity in flat plate and drag prediction | Far | FLUENT | 0 | May 19, 2010 14:47 |
drag of flat plate with cavity | Far | FLUENT | 0 | May 18, 2010 04:57 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
