ArathoN |
November 20, 2013 13:13 |
error when running sample "size 30 is not equal to the given value of 40"
Whenever i try to run the sample function i have this error:
--> FOAM FATAL IO ERROR:
file: /home/arathon/Tesi/Cases/K-E/BackwardFacingStep-15°/0/wallShearStress.boundaryField.inlet from line 26 to line 27.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
this appeared after i used the mesh from gambit, but the mesh built properly without error idem for the solver. I have all the value of the wallshearstress in the time directories.
The sample code:
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object sampleDict;
setFormat gnuplot;
surfaceFormat raw;
interpolationScheme cellPoint;
fields
"wallShearStress"
sets
lineX1
type face;
axis x;
start (0 -0.1 0);
end (2.5 -0.1 0);
nPoints 400;
surfaces
walls_interpolated
type patch;
patches ( "lowerWall" );
interpolate true;
