Heat transfer coefficient
Old   March 26, 2012, 10:58
Default Heat transfer coefficient
CIN3X is on a distinguished road
Hello to all experts and non-experts here in the forum.
I'am new to OpenFOAM (did some SimpleFoam simulations of a rotorblade), but it's the first time i am dealing with heat transfer.
My questionis:
Is there a way to calculate the heat transfer coefficient in OpenFAOM?
I searched not only this forum. The only thread i found matching this question is from the year 2005 and OpenFOAM 1.5 and there was no solution found that time.
Now we have 2012 and OpenFOAM 2.1 and i think there was alot of development in OpenFOAM, so i thought perhaps there is a simple or not so simple way of calculating the heat transfer coefficent.
My case is really simple it's a stream in a pipe. lets say the pipewall is 500K and the inletstream is 200K.
And i want the local heat transfer coefficient.
Is there any application or function to calculate the heat transfer coefficient?
With kind Regards
Viktor
CIN3X is offline   Reply With Quote
Old   March 30, 2012, 05:43
Default Htc
Learner
raghu.tejaswi is on a distinguished road
Hallo,
I also have exactly the same situation. From forums, I understand that buoyantBoussinnesqSimpleFoam solver can be used for heat transfer.
But for HTC, I think you need to first calculate the wallHeatFlux from the utility below (not sure if it will work for the latest versions).
http://openfoamwiki.net/index.php/Contrib_wallHeatFlux
The utility is obviously present in OF2.0.1 but I get an error when I try to use it. I am not sure what I can do about it.
Time = 0
Selecting thermodynamics package hsPsiThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>>
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : /localhome/bellurramesh/Thesis/ANalytical/test/constant/thermophysicalProperties::mixture, line 19, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'mixture' comprises
on line 19 the word 'air'
on line 19 the label 1
on line 19 the doubleScalar 28.9
on line 19 the label 1007
on line 19 the label 0
on line 19 the doubleScalar 1.84e-05
on line 19 the doubleScalar 0.7
as a sub-dictionary
From function const dictionary& primitiveEntry::dict() const
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 159.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam:rimitiveEntry::dict() const in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam:ureMixture<Foam::constTransport<Foam::speci eThermo<Foam::hConstThermo<Foam:erfectGas> > > >:ureMixture(Foam::dictionary const&, Foam::fvMesh const&) in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hsPsiThermo<Foam:ureMixture<Foam::constTra nsport<Foam::specieThermo<Foam::hConstThermo<Foam: erfectGas> > > > >::hsPsiThermo(Foam::fvMesh const&) in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hsPsiThermo<Foam:ureMixture<Foam::constTra nsport<Foam::specieThermo<Foam::hConstThermo<Foam: erfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#7 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/wallHeatFlux"
#8 __libc_start_main in "/lib64/libc.so.6"
#9 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/openfoam/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/wallHeatFlux"
Abbruch
Well if I succeed, I will post back and expect the same from you.
raghu.tejaswi is offline   Reply With Quote
Old   April 3, 2012, 03:07
Thanks for your answer!
I will report when i succeed or when i make some progress in calculating the htc!
kind regards Viktor
Old   November 25, 2013, 05:54
Default error with temp
david mckelvey
dmck is on a distinguished road
hi raghu tejaswi
I was wondering if you found out why you got the error you posted above, if so what does it mean?
I have seen a similar error myself and struggling to find an answer.
I'm aware this is an old thread, I was hoping you would remember.
regards
dmck
dmck is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
