5th-order scheme
Old   December 3, 2013, 09:31
Default 5th-order scheme
aiyu
aynjust is on a distinguished road
Dear Foamer, I am new to OpenFOAM, so my qestion may be slliy. I want to know what are the 5th-order scheme in the interpolationScheme. thanks
aynjust is offline   Reply With Quote
Old   December 4, 2013, 04:19
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I don't think there are any. This would be incredibly complicated to code for a unstructured solver. Also, all other integrals are 2nd order anyway ("midpoint-rule") - so why would someone want higher accuracy for some single value?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 4, 2013, 07:41
aiyu
I want to take advantage of SA - DDES model calculation under different attack angles of aerodynamic parameters, so you need to use high precision of interpolation
Old   December 4, 2013, 07:49
aiyu
I want to take advantage of SA - DDES model calculating the aerodynamic parameters of the delta wing under different Angle of attack, so you need to use high precision of interpolation
Old   December 4, 2013, 07:54
Philipp
I don't get this. Integrals are done with the midpoint rule so they are second order accurate, if you know the midpoint value with 2nd order accuracy. They are still 2nd order, if you know the midpoint value with 5th order, right? So why would you implement that in OpenFoam?
Old   December 4, 2013, 22:09
aiyu
In divScheme, how will the divergence term up to 5th-order accuracy?
Old   December 5, 2013, 02:29
Philipp
It seems that you don't understand what I tried to say, so I will try again...
The "divScheme" will determine the way the value in the middle of the face is calculated. This value is used to calculate the integral over the face. The integral will be 2nd order, even if you know the midpoint value with 10th order. So what you ask is useless.
Old   December 5, 2013, 05:04
Post
T. Chourushi
Tushar@cfd is on a distinguished road
Hello Ayun,
I don't think so it is easy task for a newbie.
Anyways, have a look to the following web-link:
HTML Code:
http://www.cfd-online.com/Forums/openfoam/94447-high-order-convective-schemes.html
I hope with this you will clear your doubts.
Tushar@cfd is offline   Reply With Quote
5th-order scheme
Gradient schemes and backward second order time scheme callumso OpenFOAM Running, Solving & CFD 4 April 19, 2021 09:36
High order scheme vs Specified Blend factor 1 realanony87 CFX 1 November 10, 2015 10:36
Solution scheme: 1st, 2nd order, etc in momentum eqs nottern Main CFD Forum 1 May 11, 2012 00:30
Higher order downwind scheme jelmer OpenFOAM Running, Solving & CFD 4 August 9, 2006 06:43
4th and 5th Order TVD Runge-Kutta Methods saygin Main CFD Forum 2 January 30, 2006 11:45
