Boundary Condition For Mapped Fields in OpenFOAM |
December 8, 2013, 21:11 |
Hasan K.J.
Rep Power: 15 |
Hi All,
I am trying to map fields between two different domains, one being the Windtunnel with blade init and the other being only a small section of the blade with symmetry on two sides. since the domains are different I am using Cutting Patches for mapping the Fields like mentioned above mapped patches inlet outlet and topandbottom I am aware that my problem is to do with boundary conditions for a fact - as the mesh is of reasonable quality with 8 million for the wind tunnel and 6 million for the smaller blade domain. and KW-SST model for both I dunno how to attach image - but the mapped domain a typical airfoil2D domain from tutorials but a smaller version it when i use the boundary conditions U inlet - Fixed Value outlet - zero gradient top and bottom - fixed value front and back - symmetry P inlet - zerogradient outlet - Fixed value top and bottom - zerogradient front and back - symmetry When i do this the Cp around the airfoil is Off by 0.2 for all around the blade i.e the cp distribution graph has just moved 0.2cp above the experimental data - even though the Cp distribution is good then also the flow behind the airfoil is much different from how it was supposed to be much faster - My question to all this is what boundary conditions can we use to map the data as it is in the Bigger domain - (the wind tunnel setup) - the Cp and the Velocity behind the airfoil is very good in wind tunnel setup and i want the same for the smaller mapped domain - as i will be using the smaller mapped domain results as the initial condition for a further LES calculations So it is important i get the right results in the smaller domain with the airfoil - I thought the problem might be because the pressure at the inlet was necessary so i put fixed value for pressure in the inlet - but then the flow starts to flow inward from the top and bottom patch due to the high pressure - then i put top and bottom as well fixed value and the that pressure interfere with the airfoil - so fixed value is not the right choice - i just need the same flow conditions that is there in the wind tunnel around the airfoil here sounds simple - but i am not able to find it -Talking about the turbulence fields, I am not able to replicate the results from the wind tunnel tunnel RANS simulation(result matches the experiments) in to the smaller domain with only airfoil without mapping the Nut, I initially mapped only P and U and had all the inlet outlet and topandbottom patch as Fixed value but the Nut did not appear any where close to the nut around the airfoil in the wind tunnel setup and I check Nut only because the velocity behind the airfoil in the wake region was not matching with the wind tunnel RANS simulation.however the Cp Matches. People suggested me that my outlet was too close to the airfoil, but my point is I am mapping the data and shouldn't be a issue right ? and the author of the paper i am trying to replicate has a similar domain but performed it in FLUENT Thanks a lot for your reply, - if u hint how to add images ill add em straight away Kind Regards, Hasan K.J Last edited by Alhasan; December 26, 2013 at 16:55. |
December 26, 2013, 16:43 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
Thanks for the advice, I will have a look at the utility, Talking about the turbulence fields, I am not able to replicate the results from the wind tunnel tunnel RANS simulation(result matches the experiments) in to the smaller domain with only airfoil without mapping the Nut, I initially mapped only P and U and had all the inlet outlet and topandbottom patch as Fixed value but the Nut did not appear any where close to the nut around the airfoil in the wind tunnel setup and I check Nut only because the velocity behind the airfoil in the wake region was not matching with the wind tunnel RANS simulation.however the Cp Matches. People suggested me that my outlet was too close to the airfoil, but my point is I am mapping the data and shouldn't be a issue right ? and the author of the paper i am trying to replicate has a similar domain but performed it in FLUENT Regards, Hasan K.J |
December 26, 2013, 17:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Hasan,
Thank you for starting a new thread for this topic. For other readers, the initial discussion started on this thread: http://www.cfd-online.com/Forums/ope...g-utility.html You can find an explanation on how to attach files in the FAQ of the forum (yellow menu above, 3 entry from the left). More specifically, the instructions are here: http://www.cfd-online.com/Forums/faq...l&titlesonly=0 OK, I'm trying to figure out a way to give you a way to visualize in your mind the problem at hand... The simplest idea I can come up with is the force-moment relation. If you have a pen and try to bend it by only holding the extremities, it's rather difficult to bend and/or break the pen; but if you hold it near the centre and use the rest of the pen to hold with your hands, it's rather easy to break the pen, since you're able to apply more force and moment to the whole pen. Another example would be if you were trying to run inside a 2x2 meter room on top of a treadmill vs running outside. The same might be happening in this case, namely the smaller domain is too small and leads to the air flow to be too constricted, which leads to it to sort-of bend itself in order to flow around the blade, which leads to the Cd being offset by a bit. My guess is that either the symmetry planes should not be used (perhaps slip wall would be best?) or that the inlet should be one of those fancy pressure-based ones... if you look at the Inlet ones pointed from here: http://foam.sourceforge.net/docs/cpp/a00001.html
Best regards, Bruno
December 26, 2013, 17:29 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
I totally agree with the boundary condition being too close poses an issue -but I had to do it there was no other option 1) the airfoil is 0.56 chord lengths far from the wind tunnel exit so the C grid could go only so far in front for mapping 2) The paper I am trying to replicate is by an author who has 7 papers on a domain with a same size - i have used his domain size and he has successfully performed the simulation but dunno how he did it he used FLUENT to do it though the link for the paper http://arc.aiaa.org/doi/abs/10.2514/6.2009-3197 the experimental setup http://www.mb.uni-siegen.de/iftsm/fo..._etal_fn07.pdf so without mapping and without using a smaller domain, the number of cells necessary to perform this LES simulation in 3D with the wind tunnel in unimaginable. - please have a glance at Fig.7 in the experimental Setup and throw ideas of how this simulation could be done - other than the method i am currently trying of mapping - Images below - (Left)- Full Windtunnel Simulation (matches the experimental results for Cp and Wake Flow) (Middle)-Mapped right after mapping - before the simulation (right) - after the simulation (have a look at wake flow behind the airfoil doesn't match the experimental, however Cp is accurate) Thanks Hasan K.J |
December 26, 2013, 18:49 |
Bruno Santos
Rep Power: 128 |
Hi Hasan,
Yeah, from the images, it's what I was imagining. The even simpler idea is that even though you are using symmetry boundary conditions on top and bottom, they essentially act as flow walls. This forces the fluid to respect those "walls" and therefore enforces the wake to go more upwards than it should (if I'm seeing it correctly). Given the descending ramp after the blade, even the slip boundary condition will not be the correct solution. You have to keep in mind that the fluid still acts as sort-of incompressible, therefore either it has to speed up or increase the pressure, which will lead to the distortion of the flow. The simplest idea that comes to mind is this:
Best regards, Bruno
December 26, 2013, 19:04 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
Thanks, you have slightly misunderstood the problem, or i have to blame myself, I am so bad in explaining stuff - I have tried all boundary conditions that i know of i will explain - Symmetry is used for the "front and back" of the geometry not the top and bottom. - I have tried Slip for "top and bottom" and the Cp also doesn't match so its useless - I tried Zerogradient - Useless - I tried FixedValue - Treat the "top and bottom" it as a inlet and that solved the problem.of the Cp - I have also tried "inletOutlet" for U and "outlet Inlet" for P for the "Top and bottom" patch works fine - but Cp is slightly off - I have wasted more than 240 hours of Computing time 128 processors on these boundary conditions - i feel ashamed they dedicated me a 10 day slot - For the outlet i have tried Zerogradient, InletOutet, OutletInlet, FixedValue Nothing Seems to do any changes to the Wake Flow !!!! which is what surprised me - after some discussion in LikedIN came to conclusion that Nut might the Culprit as the turbulence fields from the wind tunnel has to be mapped, But even that has failed me as of now - So, looking at other options such as Merging mesh and GGI is the only option i think - Im open for any suggestions Regards, Hasan K.J |
December 26, 2013, 19:18 |
Bruno Santos
Rep Power: 128 |
OK, that does make it a bit clearer.
But... for example, is the top patch both the horizontal and the inclined patches on the top? Or are they "top1" and "top2"? |
December 26, 2013, 19:29 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
It is both the Horizontal and Inclined Bit together - so finally the working BC for Top and Bottom to give me a good Cp is the FixedValue BC - Tried everything I know - no luck with the Wake, if you look at the images, you can see that the wake is not turning enough and the answer could be after mapping the Nut toward the outlet will be a lot. Thanks, hasan K.J |
December 26, 2013, 19:40 |
#9 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
Theoretically speaking i shouldn't have any issues right ? because my solution from the wind tunnel is converged and i an using the same flow filed all around the airfoil ? - that is the reason i kept saying boundary condition issue in all the forums i could !!! -coz i can't point out another issue !!! since the author has actually used the same geometries - or am i just trying to do something that is not even possible.. ??? Regards, Hasan K.J |
December 26, 2013, 19:51 |
#10 |
Bruno Santos
Rep Power: 128 |
From what I can see and understand, the coarser mesh before mapping, gave better looking values simply because of mere luck.
The cells are too rectangular shaped, which lead to a distortion of the flow. Examples: OpenFOAM: Interesting cases of bad meshes and bad initial conditions The top part should not be a single patch, same goes for the bottom one. The horizontal parts can easily be slip, but the inclined ones should use "outletInlet" (or "inletOutlet", I haven't checked). Using fixed value on either one has one advantage: it enforces the flow to keep on going along the main flow orientation. Problem is that it does not account for the effect of some occasional vortexes that the blade could introduce into the flow. In other words, does not account for small expansions and contractions of the flow. |
December 26, 2013, 20:58 |
#11 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
I have already tried InletOutlet BC for the "topandbottom" patch, do you think making the inclined ones separately, will make a a difference..? and slip for the horizontal are affecting for the upper surface, and Cp on the upper surface. Thanks, Hasan K.J |
December 26, 2013, 23:05 |
#12 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
I used mergeMeshes to merge two meshes and what i have ended up is with the patches i had in both the meshes in the boundary file inlet -for small domain type cyclicAMI; nFaces 60; startFace 10560; matchTolerance 0.0001; neighbourPatch outsideSlider;// what do i put here..? When i use AMI what do i say for the neighbourPatch ? what BC should i give for say U and P for these Patches ? they cannot be fixedValue can they be..? so what should i assign then ? Inlet i have fixedValue usually ?- since i made it cyclicAMI here what do i put inside the boundary file Regards, Hasan K.J [Moderator note: Moved this post from this thread: http://www.cfd-online.com/Forums/openfoam-solving/95697-problem-using-ami-10.html ] Last edited by wyldckat; December 27, 2013 at 15:47. Reason: added moderator note... |
December 27, 2013, 00:30 |
#13 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
From my research into this, it is best that i do an mesh merge and and AMI case and I have only enough time to run one more case due to time constraints !! I have merged the meshes and I have asked a question here http://www.cfd-online.com/Forums/ope...tml#post467808 Since you say the mesh is too coarse i will increase the density - the mesh that appears to be coarse has 7 million cells i could 11 max and more than that its gonna take too much time probably make a bigger refinement box and that should do - during snappy - what did u mean try not to over lap the meshes ? here: http://www.cfd-online.com/Forums/ope...tml#post467799 - do mean to say the big mesh has to have an empty space in the middle for me to put another mesh and only then it can be merged ? - Can you please share if you have any case with AMI ! !? I read all night still it hasn't gone through my head of the neighbouring patch and the boundary contains that has to be used, - AMI is the Last Stand Thanks for your time, Regards, Hasan K.J |
December 28, 2013, 15:50 |
#14 | |||||
Bruno Santos
Rep Power: 128 |
Hi Hasan,
Having the top patch divided into the two parts of "top" and "top_inclined", and similarly done for the bottom, should help you with having better adjusted boundary conditions for your case. Given the complexity of the geometry, I think that if you use that coarse mesh you have and separate the patches as mentioned, then try out the boundary conditions mentioned, namely:
If the door is to fit properly in that hole, it cannot be too big, nor too small and its mechanical parts must be properly aligned with the ones on the hole. If by any chance one of those mechanical parts have a slight non-alignment, the door will not close because it will hit the wall <- this is overlapping Quote:
But the actual instructions on how to set this up is shown here: http://www.cfd-online.com/Forums/ope...tml#post446517 post #184 - which in answer to your previous question, the "neighbourPatch" is the patch name on the other mesh part. Best regards, Bruno
December 28, 2013, 16:02 |
#15 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
- for some reason i thought mesh merging was more like snappy hex i though it was going to get rid of all the overlaping mesh of the external mesh within the internal mesh and retain only the mesh that it is merging (internal ones) I read through the forums and kinda figured out how the Mesh merging works, so currently I am making a External mesh with a hole in the middle so i can place my refined mesh in it, I am using snappy hex to do it, lets hope it works. - so current plan is make the hole a single patch and for the internal mesh - make all of the patches that is going to be in contact with the external mesh as a single patch. and then they gonna be neighbours !!! and toposetsDict will be created automatically i guess, lets hope i have got it right. -Does GGI work the same way ? do i need a hole in the mesh to put another mesh or that doesn't matter ? the other mesh can interpolate the data from within the external mesh ? Thanks Bruno, Kind Regards, Hasan K.J |
December 28, 2013, 16:19 |
#16 | ||
Bruno Santos
Rep Power: 128 |
Having a single patch on each side should work, but I would suggest that you try to keep a 1:1 approach for each major patch you already have on the internal mesh, so that you can better diagnose "what is flowing through where". Quote:
So... to answer your question: in theory, it should work with GGI as well, in a very similar way. But in practice, I don't even know how to use GGI |
December 28, 2013, 16:31 |
#17 |
Hasan K.J.
Rep Power: 15 |
I kind of get it now
But is there any method of Mapping the fields between two geometries as the simulation is running, like in AMI and GGI, I am thinking we need a patch on both meshes where the flow is going to be transferred but i was wondering if there was some function that interpolates from within one mesh to the patch of the other mesh as the simulation was running. rather than having a patch on same location on both meshes !! Thanks, Hasan K.J |
December 28, 2013, 16:44 |
#18 |
Bruno Santos
Rep Power: 128 |
AFAIK, most of the patch mapping BCs available in OpenFOAM need a 1:1 face association. The only able to perform face-area weighted mapping is AMI (and GGI).
But feel free to browse through the official list of BCs here: http://foam.sourceforge.net/docs/cpp/a00001.html |
December 28, 2013, 16:59 |
#19 |
Hasan K.J.
Rep Power: 15 |
Hey Bruno,
The above link is very very helpful i have been using open foam 2years now, i never came across it By anychance do you know any blog or any forum that describes - how to make a good snappy hex mesh on complicated geometries ? it would be very help full - what ever i do in snappy hex i always loose some small bits and bobs of my geometry, and i dunno how to avoid it !!!!! Thanks, Hasan K.J |
December 28, 2013, 17:03 |
#20 | |
Bruno Santos
Rep Power: 128 |
boundary condition, mapfields, openfoam |
Display Modes | |
questions about boundary condition type of openfoam 2.2.0 | shuoxue | OpenFOAM Pre-Processing | 3 | May 27, 2013 02:47 |
Ship wave Boundary Condition in OpenFoam | keepfit | OpenFOAM Running, Solving & CFD | 1 | May 24, 2012 11:24 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 01:55 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
