Can run setFields in parallel while decomposed? |
December 9, 2013, 04:34 |
Youngkook Kim
Rep Power: 12 |
I am running interfoam with quite a heavy mesh on 24 CPU. And I need to test with several meshing case. For this, what I am doing now is: 1. blockMesh 2. decomposePar(meshes are decomposed) 3. mpirun -np 24 snappyhexmesh.exe -overwrite -parallel 4. reconstructparMesh 5. (prepare fields including alpha1. in 0 directory) 6. setfields 7. decomposePar 8. run the solver in parallel Only if I can run setfields while decomposed, I can save more time. However, error occurs at step 5 with followings: 1. blockMesh 2. (prepare fields including alpha1. in 0 directory.) 3. decomposePar (mesh and fields in 0 are decomposed) 4. mpirun -np 24 snappyhexmesh.exe -overwrite -parallel 5. mpirun -np 24 setfields.exe -parallel -> ERROR 6. run the solver Do you know what is wrong for setfields in parallel?? |
December 9, 2013, 22:39 |
Youngkook Kim
Rep Power: 12 |
I found the patch created by SHM is not shown in Paraview... It's because the patch is not created when I decompose(this is before running SHM). I added the patch with empty in 'boundary' before decomposing, and it's settled. But error still persists with setfields with parallel. The error message is:
keyword procBoundary16to12 is undefined in dictionary "C:\~~~~~\alpha1::boundaryField" Boundaryfield for the SHM patch is defined in 0 folder. But I cannot read alpha1 in the decomposed 0, probably it's in binary. I hope someone can give an advice. Last edited by totalart; December 10, 2013 at 00:00. |
August 20, 2018, 23:07 |
anw
Chaewoong Ban
Rep Power: 12 |
1. blockMesh
2. (prepare fields including alpha1. in 0 directory.) ** just put boundaryField such as "procBoundary.*" in your alpha1. file "procBoundary.*" { type processor; value uniform 0; } 3. decomposePar -copyZero(mesh and fields in 0 are decomposed) 4. mpirun -np 24 snappyHexmesh -overwrite -parallel 5. mpirun -np 24 setFields -parallel -> ERROR 6. run the solver |
dynamicMesh parallel run | popcorn | OpenFOAM Running, Solving & CFD | 0 | October 2, 2012 12:34 |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Parallel run in fluent for multiphase flow | apurv | FLUENT | 2 | August 3, 2011 19:44 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
