December 17, 2013, 20:21 |
Water level rises in LTSinterfoam???
Youngkook Kim
Rep Power: 12 |
While I was running LTSinterfoam to calculate ship resistance, I found something funny. I just used Wigley tutorial and changed hullform and made meshes finer. But water level starts rising and ship is almost sinking at the time 15000s. My alpha1 is following(same with Wigley tutorial). Anyone has idea??? I uploaded screenshot at time step 0, 8000 and 15000. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type zeroGradient; } sides { type symmetryPlane; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } hull_patch0 { type zeroGradient; } } // ************************************************** *********************** // ALPHA_T0.jpg ALPHA_T8000.jpg ALPHA_T15000.jpg And can anyone tell me how to set the time step for LTSinterfoam? I think it's different from interfoam, therefore, we don't need to keep CFL below 1.0. Youngkook Kim |
February 27, 2014, 23:22 |
Rep Power: 14 |
did you try reducing the time step size?
April 23, 2014, 07:34 |
Youngkook Kim
Rep Power: 12 |
Sorry, I didn't notice your posting. As I mentioned, it is LTS(Local Time Stepping) solver. Therefore, the time step in controlDict is no meaning. I set MaxCo up to 0.1 but there was no change... It happens for some cases while others are okay... I couldn't find the reason yet.
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
Discontinuity at water level in stratified 2 phase flow | kbaker | CFX | 24 | June 14, 2012 07:37 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
