potentialFoam fatal error
I am continuously getting the following error..
Kindly help. Foam Fatal Error: Create time Create mesh for time = 0 reading field p ------> FOAM FATAL IO ERROR cannot find file file: /home/shantanu/Desktop/tutorials/basic/potentialFoam/cylinder/0/p at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
OF is not able to locate your 'p' file in the zero time folder. Your case should have 3 folders. 1) Folder '0' that contains your fields (p,U,k etc). 2) Folder 'constant' that has your mesh details and 3) The 'system' folder which contains the solver/solution information. Check if you have all the files in the respective folders and then run your commands from the terminal where these folders are located.
Thanks a lot... the time directory was 0.org I changed it to 0. Now I am getting error in paraFoam. AtSpi Adaptor error it is.. Problem with child ids..
Kindly help.. |
could you post the detailed error message please?
Segmentation fault (core dumped) is the error while running the specific cases for cylinder., say streamlines.
Another error is like: fileName::stripInvalid() called for invalid fileName UbuntuOne For debug level (= 2) > 1 this is considered fatal Aborted This error occurs when paraFoam is run without any case. |
for the fileName::stripInvalid() error, Im guessing that you might be having a folder or file with the name 'UbuntuOne' within the case directory with blank spaces in the file/folder name(i.e Ubuntu(space)One.try renaming it without spaces or with a underscore like Ubuntu_one or UbuntuOne..if I were you, I wouldnt keep anything irrelevant apart from the files related to the case within the case directory). And also take care in defining file names since most of the *nix systems do not like spaces in file/folder names.
About the paraFoam error, I have no idea why this is happening. I could give a try if you could send me across your files. cheers. |
Thanks a lot...... It worked. There was a space in the file name. Once I removed that, it worked. Perfectly.
May I know your e-mail / linkedin details please? I searched you on linkedin, but could not find. Thank you. |
