How to incorporate inflow velocity as an input file
Old   December 31, 2013, 06:37
Default How to incorporate inflow velocity as an input file
Bobby
babakflame is on a distinguished road
Dear Foamers
I want to simulate a combustible case with LES in which the fuel jet has a fully developed profile that originates from a 46 m/s velocity. I mean with applying 46 m/s to a pipe we can derive the final fully developed velocity. I do this by extending the inflow as a pipe and let the profile to take the fully-developed shape. However, this culminates into dropped inflow temperature about 10 degrees. Here is my Pressure file:
internalField   uniform 101325;
boundaryField
    inletfuel
        type            zeroGradient;
    inletair
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 101325;
    burnerwall
        type            zeroGradient;
    outlet2
        type            fixedValue;
I have used zeroGradient for the wall of the inflow pipe and the inlet of the pipe.
My Question is that Is there any way to read the inflow data from a saved file and get rid of the dropped pressure and temperature and also increased grid points of the extended pipe for fuel jet?
If somebody has a tutorial for this case would you PLZ attach it for me or if O.F. tutorial has this case, would somebody hint me where it is?
Regards
Bobi
babakflame is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
