k-Epsilon thermal simulation
Old   January 7, 2014, 11:55
Default k-Epsilon thermal simulation
Kapa Lilla
klilla is on a distinguished road
Dear All,
I'm using a temperature equation version of the simpleFoam solver. I did an isothermal periodic channel flow simulation with Re_tau=150 and used both k-epsilon and v2f turbulence models. It is a resolved simulation, so I used the low-Re version of the k-Epsilon model. The results are fairly reproduced the reference DNS data.
After I've switched to a heated case and there I got problem with the k-Epsilon (the v2f remained adequately good in therms of the momentum boundary layer). Surprisingly, the momentum BL has changed, though, the temperature should be only acts as a scalar transport (no buoyancy). Could anyone tell me what could go wrong? I've tried different boundary conditions, turbulent Pr numbers. I tried the 2 low-Re models. Whatever I did, the velocity gradient normal to the wall reduces with 30%, approximately.
Thank you for your help,
Lilla
klilla is offline   Reply With Quote
Old   August 29, 2017, 06:52
Peter Baskovich
pete20r2 is on a distinguished road
Hi, I realise I am a bit late but I'd like to discuss this.
Did you check your thermophysical properties? There could be a thermal thinning term in there.
Also, how are you handling the T field periodically?
pete20r2 is offline   Reply With Quote
channel flow, k-epsilon, low-re, simplefoam, thermal analysis
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 17:26
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Initial k & epsilon for engine simulation Tomislav Sencic Main CFD Forum 1 November 27, 2007 05:21
Thermal cycling simulation - FAN issue Jean-Baptiste Main CFD Forum 4 April 19, 2007 09:02
