Backtrace errors while running on a HPC with buoyantBoussinesqSimpleFoam
Old   January 12, 2014, 21:26
Default Backtrace errors while running on a HPC with buoyantBoussinesqSimpleFoam
Thangam Natarajan
Thangam is on a distinguished road
I encountered this error while running a job on a HPC. The job was aborted with this error. However, when I rescheduled the same to job to continue from the latestTime, it continued without any error. Any ideas on why this happened?
buoyantBoussinesqSimpleFoam:10105 terminated with signal 7 at PC=507590 SP=7fffb7654708.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10112 terminated with signal 7 at PC=507590 SP=7fff19623c88.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10113 terminated with signal 7 at PC=507590 SP=7fff360e7b08.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10106 terminated with signal 7 at PC=507590 SP=7fffa422d488.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10108 terminated with signal 7 at PC=507590 SP=7fff43220788.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10109 terminated with signal 7 at PC=507590 SP=7fff7e663388.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10111 terminated with signal 7 at PC=507590 SP=7fffdb30f808.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10107 terminated with signal 7 at PC=507590 SP=7fffb1dfb588.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10110 terminated with signal 7 at PC=2b3ff3a12690 SP=7fff5e99a128.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10104 terminated with signal 7 at PC=507590 SP=7fff9e866e08.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10792 terminated with signal 7 at PC=3557609a43 SP=7fff5c925130.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10791 terminated with signal 7 at PC=2b920bf0a070 SP=7fff87390738.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10399 terminated with signal 7 at PC=2aae1a9a8070 SP=7fffab21e7f8.
 Backtrace:
 buoyantBoussinesqSimpleFoam(_intel_fast_memcpy+0x0)[0x507590]
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam21processorFvPatchFieldIdE21up
 dateInterfaceMatrixERKNS_5FieldIdEERS3_RKNS_9lduMatrixES5_hNS_8UPstream10commsTypesE+0x371)
 [0x2b5dca08dd11]
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam9lduMatrix22updateMatrixInterfaces
 ERKNS_10FieldFieldINS_5FieldEdEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKNS2_IdEERSC_h+0x339
 )[0x2b5dcc652d69]
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam9lduMatrix4AmulERNS_5FieldIdEERKNS
 _3tmpIS2_EERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEh+0x243)
 [0x2b5dcc650a23]
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0x
 8bc)[0x2b5dcc65e79c]
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dicti
 onaryE+0x688)[0x2b5dca3cd378]
 buoyantBoussinesqSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x11b)[0x46259b]
 buoyantBoussinesqSimpleFoam[0x423287]
 /lib64/libc.so.6(__libc_start_main+0xfd)[0x30a281ecdd]
 buoyantBoussinesqSimpleFoam[0x4214d9]
 buoyantBoussinesqSimpleFoam:9761 terminated with signal 7 at PC=2ad7de11a070 SP=7fff1b9a6f38.
 Backtrace:
 buoyantBoussinesqSimpleFoam:10400 terminated with signal 7 at PC=304f609a43 SP=7fffa6c2e370.
 Backtrace:
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so(+0x16e690)
 [0x2b3ff3a12690]
 buoyantBoussinesqSimpleFoam:9762 terminated with signal 7 at PC=3cdc80df45 SP=7fff0509d690.
 Backtrace:
 buoyantBoussinesqSimpleFoam:9763 terminated with signal 7 at PC=2aeeaadb7370 SP=7fff094f61c8.
 Backtrace:
 /group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libfieldFunctionObjects.so(+0x8f370)
 [0x2aeeaadb7370]
 [0x2ac5c17f7d11]
 )[0x2ac5c3dbcd69]
 [0x2ac5c3dbaa23]
 8bc)[0x2ac5c3dc879c]
 onaryE+0x688)[0x2ac5c1b37378]
 [0x2b4dc0073d11]
 )[0x2b4dc2638d69]
 [0x2b4dc2636a23]
 8bc)[0x2b4dc264479c]
 onaryE+0x688)[0x2b4dc03b3378]
 [0x2ad0cba0ad11]
 )[0x2ad0cdfcfd69]
 [0x2ad0cdfcda23]
 8bc)[0x2ad0cdfdb79c]
 onaryE+0x688)[0x2ad0cbd4a378]
 [0x2ae02173dd11]
 )[0x2ae023d02d69]
 [0x2ae023d00a23]
 8bc)[0x2ae023d0e79c]
 onaryE+0x688)[0x2ae021a7d378]
 [0x2ae010494d11]
 )[0x2ae012a59d69]
 [0x2ae012a57a23]
 8bc)[0x2ae012a6579c]
 onaryE+0x688)[0x2ae0107d4378]
 [0x2b8dfcbdfd11]
 )[0x2b8dff1a4d69]
 [0x2b8dff1a2a23]
 8bc)[0x2b8dff1b079c]
 onaryE+0x688)[0x2b8dfcf1f378]
 [0x2b3a42c51d11]
 )[0x2b3a45216d69]
 [0x2b3a45214a23]
 8bc)[0x2b3a4522279c]/group/fdrg/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dicti
 onaryE+0x688)[0x2b3a42f91378]
 Sorry!  You were supposed to get help about:
     odls-default:could-not-kill
 But I couldn't open the help file:
     /ivec/devel/intel/12.1.7/openmpi/1.6.5/share/openmpi/help-odls-default.txt: Interrupted
 system call.  Sorry!
 buoyantBoussinesqSimpleFoam:10382 terminated with signal 7 at PC=2b6086d8f070 SP=7fffe8f4e138.
 Backtrace:
 mpirun noticed that process rank 61 with PID 10107 on node e530 exited on signal 7 (Bus
 error).
Thangam is offline   Reply With Quote
Old   July 11, 2014, 11:45
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
I saw a similar error these days. Have you found an answer?
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 11, 2014, 23:39
Thangam Natarajan
I did not go much into details but I understood (after some googling!) that
signal 7 is a bus error. Which you can see from:
error).
I am not sure about the details though. However, some explanations for the bus error:
A "Bus Error" may come, for example, from accessing unaligned data (i.e. like trying to access a 4 byte integer with a pointer to the middle of it). What this means will vary from platform to platform. (I haven't come up with a good example of this one yet.)
A "Bus Error" can also often indicate a memory overwrite, e.g. somebody wrote a number where a pointer is kept. Often caused by going past the end of an array and into the system pointers at the start of the next memory block.
buoyanboussinesqsimple, error, hpc
Errors in running "wmake" Thamali OpenFOAM Programming & Development 5 November 11, 2013 07:40
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Errors in running a icoFsiFoam case jin_xu OpenFOAM Pre-Processing 0 June 9, 2008 06:48
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
