January 19, 2014, 17:00 |
Varying time step
erik gustafsson
Rep Power: 12 |
Is it possible to set a fixed varying time step in openfoam? Let say i want
deltaT = 0.0001 if t>=0 && t<=1 deltaT = 0.001 if t>1 && t<=2 deltaT = 0.01 if t>2 && t<=3 If there is i would be really happy if someone have an example of this. At the moment I'm not satisfied with adjustableTimeStep. Thanks |
January 19, 2014, 21:22 |
Eric Robertson
Rep Power: 14 |
This is certainly possible if you modify the source code of the particular solver you want to use. Would require a set of if statements.
January 20, 2014, 01:54 |
Josh
Rep Power: 12 |
A less-than-elegant solution might be just to run a bash script which replaces the controlDict file and runs the solver again.
January 20, 2014, 03:55 |
You can create 3 different controlDicts with required deltaT parameter and then use function objects to update control dictionary during the time. Put something like: Code:
functions { fileUpdate1 { type timeActivatedFileUpdate; functionObjectLibs ("libutilityFunctionObjects.so"); outputControl timeStep; outputInterval 1; fileToUpdate "$FOAM_CASE/system/controlDict"; timeVsFile ( (-1 "$FOAM_CASE/system/controlDict_1") (1 "$FOAM_CASE/system/controlDict_2") (2 "$FOAM_CASE/system/controlDict_3") ); } } So from the beginning of the simulation it will use controlDict_1 where you put deltaT=0.0001, from 1 to 2 s it will use controlDict_2 where you put deltatT=0.001 etc. |
January 20, 2014, 03:58 |
#5 | |
erik gustafsson
Rep Power: 12 |
(-1 "$FOAM_CASE/system/controlDict_1") (1 "$FOAM_CASE/system/controlDict_2") (2 "$FOAM_CASE/system/controlDict_3") -1 / 1 / 2 is those number related to time? |
January 20, 2014, 06:37 |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
