January 20, 2014, 04:51 |
3D dambreak
Rep Power: 12 |
Hi all
I am trying to simulate a 3D dambreak case in intterFoam, its the first time am trying 3D. I don't understand how to mesh the water column in 3D for dambreak. When I tried with setting the 'setFieldsDict' similar to 2D case, my red surface representing water is seem to move with in that column only and not in the horizontal direction as it usually happens. Can any one kindly suggest how to simulate the water column. Any help will be a great privilege. Thanks in advance regards Sujatha |
January 20, 2014, 05:18 |
Christian Wokl
Rep Power: 14 |
I'm sort of having a similar problem. I am simulating a spillway and my water column is stuck in the beginning of the slope. I would be very thankful if u could inform me if u solve urs and, of course, i'll let u know when i solved mine. christian |
January 20, 2014, 09:19 |
Rep Power: 12 |
Sir Wokl,
I am stuck with it right now, but once I get some hint, for sure I will post it here. regards Sujatha |
January 20, 2014, 10:47 |
Rep Power: 13 |
I think the best you can do to get help is to attach your case and/or pictures.
It is rather difficult to understand what the problem is with the current description. |
January 20, 2014, 11:42 |
Pablo Higuera
Rep Power: 19 |
Hi Sujatha,
have you changed the direction of gravity? You can find it in ./constant/g Best, Pablo |
January 20, 2014, 11:48 |
Christian Wokl
Rep Power: 14 |
hey,
i cant tell if i figured it out now but it seems to get better my problem at first was, that i needed a reservoir (rather large) filled with water. guess this depends on ur geometry and what ur planning to simulate. If u don't have an inlet and just observing the coloumn of water breaking, i guess u won't need one. If u have an outlet for water and air, depending on ur boundary condition, the outlet should be in the negative quadrant of x-coordinate. if just air flows out through the atmosphere u can ignore that as well. double checking the direction of gravity is also very useful good luck christian i will let u know if i solved my problem |
January 20, 2014, 14:19 |
#7 | |
Chris DeGroot
Rep Power: 17 |
January 20, 2014, 22:25 |
Rep Power: 12 |
Thanks a million, sir Startingwith CFD, sir Phicau, sir Cdegroot and sir Wokl, for your kind responses.
My problem was with the direction of 'g', I changed it corresponding to my axes and now its working. 'g' has to be in the vertical direction, but by mistake I had placed it in the third direction. Thank you all again regards Sujatha |
Display Modes | |
DamBreak - Convert from 2D to 3D - Problems | unikrsn | OpenFOAM | 11 | October 22, 2021 06:40 |
dambreak tutorial's weird velocity field. | sharonyue | OpenFOAM | 8 | October 18, 2016 15:57 |
dambreak switched properties boundary | anon_n | OpenFOAM Running, Solving & CFD | 4 | October 28, 2013 10:22 |
[General] Water surface profile in OpenFoam dambreak case | kerim | ParaView | 3 | February 20, 2012 04:52 |
dambreak problem | upqiang | FLUENT | 3 | November 23, 2009 10:16 |
