January 21, 2014, 07:39 |
Initiate density
erik gustafsson
Rep Power: 12 |
Hello
I work with a compressible simulation with rhoPimpleFoam. My goal is to empty an air tank with initial pressure at 9 bar, the rest of the domain is 1 bar. I set initial temperature and pressure with setFields but my highly compressed region of air shall have a higher density. Is it possible to set the density in a similar way? Thanks! //Erik |
January 21, 2014, 11:32 |
Nima Samkhaniani
Rep Power: 24 |
as it compressible flow,are you sure, you want to initiate density at all? because density will be update with pressure and temperature, am i missing anything?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
January 21, 2014, 13:28 |
erik gustafsson
Rep Power: 12 |
Yeah perhaps but i think i make something really wrong here. I have an air tank which is filled to 9 bar so i assume that the temperature are the same in the tank as outside 300K. In fvsolution i set rhoMax to 90 and rhoMin to 1.2 which seems okey. But i always got problem with convergency of the temperature. Do i make any fatal mistakes ?
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
How to model Salinity, density, fresh water & sea water | grayback87 | FLUENT | 3 | December 30, 2014 02:00 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
