Constructing vector from three scalars
Like Tree1Likes
  • 1 Post By mayank.dce2k7
Old   January 24, 2014, 16:37
Default Constructing vector from three scalars
India
mayank.dce2k7 is on a distinguished road
Hi Foamers,
I have a simple question.....I have a vector defined as below:
const vector& r=p.position();
I have two components found as below:
scalar e= r.x(); scalar c=r.y();
I want to define a vector such that:
vector f= (e c 0);
where e & c are x-component and y-component respectively.......
I have tried tons of combination but I am getting error. I am not good as C++ so please help.....
Regards,
Mayank
kk415 likes this.
mayank.dce2k7 is offline   Reply With Quote
Old   January 24, 2014, 16:59
Lieven
Lieven will become famous soon enough
Hi Mayank,
Simply try
vector f(e,c,0);
Cheers,
L
Lieven is offline   Reply With Quote
Old   January 27, 2014, 18:00
India
Thanks a lot Lieven.
I have an additional question:
since vector r=p.position(); its each component will have dimension 'meters'. Will my vector f(e,c,o) will also have dimensions of 'meters' and what will be the units associated with scalar e,c? ALso, if they are all unit less then how can I associate proper units with them?
Old   January 27, 2014, 22:45
lixx is on a distinguished road
What you need are dimensionedVector and dimensionedScalar.
lixx is offline   Reply With Quote
Old   January 28, 2014, 01:08
India
Lixx, thanks for the reply.
Ya, you are right. I tried but couldn't get it right.Is there a simple way in which I can define vectors and scalars with their dimensions for immediate use in same file? I just want to use it in one file in lagrangian particle force library and then compile it.
Old   January 28, 2014, 02:21
Lieven
Hi Mayank,
To construct a dimensionedScalar and dimensionedVector:
    dimensionedScalar scalarTest("s",dimLength,1.0);
    dimensionedVector vectorTest("v",dimLength,vector(1,1,1));
In your case, you could therefore write something like
dimensionedVector f("f",dimLength,vector(r.x(),r.y(),0));
But I'm wondering if the position() routine does not return a dimensionedVector directly. If that's the case you can write something as:
dimensionedVector f = p.position();
f.component(Vector::Z) = 0;
Cheers,
Lieven
Old   January 28, 2014, 02:49
India
Thanks Lieven. I'll give it a shot and let u know.
"dimLength" is for length in case one has to define velocity then what will be the replacement of "dimLength"?
Old   January 28, 2014, 03:36
You can refer to $src/OpenFOAM/dimensionSet/dimensionSets.H, where $src means the src directory in your OpenFOAM installation.
extern const dimensionSet dimless;
extern const dimensionSet dimMass;
extern const dimensionSet dimLength;
extern const dimensionSet dimTime;
extern const dimensionSet dimTemperature;
extern const dimensionSet dimArea;
extern const dimensionSet dimVolume;
extern const dimensionSet dimVol;
extern const dimensionSet dimDensity;
extern const dimensionSet dimForce;
extern const dimensionSet dimEnergy;
extern const dimensionSet dimPower;
extern const dimensionSet dimVelocity;
extern const dimensionSet dimAcceleration;
extern const dimensionSet dimPressure;
In your case you should use 'dimVelocity'.
Old   January 28, 2014, 17:07
India
Thank you guys for your help. I tested what u guys suggested.
I tried something like this:
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
template<class CloudType>
Foam::forceSuSp Foam::newForce<CloudType>::calcNonCoupled
    const typename CloudType::parcelType& p,
    const scalar dt,
    const scalar mass,
    const scalar Re,
    const scalar muc
) const
    forceSuSp value(vector::zero, 0.0);
dimensionedVector D("D", dimForce, vector(1.0,0,0));
    value.Su() = D;
    return value;
I made sure that I assign 'value.Su()' a vector with dimension that of force but when I compiled the library i got these error messages:
Making dependency list for source file parcels/derived/basicReactingMultiphaseParcel/makeBasicReactingMultiphaseParcelSubmodels.C
Making dependency list for source file parcels/derived/basicReactingParcel/makeBasicReactingParcelSubmodels.C
Making dependency list for source file parcels/derived/basicThermoParcel/makeBasicThermoParcelSubmodels.C
Making dependency list for source file parcels/derived/basicKinematicCollidingParcel/makeBasicKinematicCollidingParcelSubmodels.C
Making dependency list for source file parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C
SOURCE=parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/lagrangian/basic/lnInclude -I/opt/openfoam211/src/lagrangian/distributionModels/lnInclude -I/opt/openfoam211/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam211/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam211/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/opt/openfoam211/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/opt/openfoam211/src/thermophysicalModels/properties/solidProperties/lnInclude -I/opt/openfoam211/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/opt/openfoam211/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam211/src/thermophysicalModels/SLGThermo/lnInclude -I/opt/openfoam211/src/thermophysicalModels/radiationModels/lnInclude -I/opt/openfoam211/src/turbulenceModels -I/opt/openfoam211/src/transportModels/ -I/opt/openfoam211/src/transportModels/incompressible/lnInclude/ -I/opt/openfoam211/src/turbulenceModels/incompressible/turbulenceModel/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/RAS/lnInclude -I/opt/openfoam211/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/LES/lnInclude -I/opt/openfoam211/src/regionModels/regionModel/lnInclude -I/opt/openfoam211/src/regionModels/surfaceFilmModels/lnInclude -I/opt/openfoam211/src/dynamicFvMesh/lnInclude -I/opt/openfoam211/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeBasicKinematicParcelSubmodels.o
In file included from lnInclude/newForce.H:125:0,
from lnInclude/makeParcelForces.H:39,
from parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:31:
lnInclude/newForce.C: In member function ‘Foam::forceSuSp Foam::newForce<CloudType>::calcNonCoupled(const typename CloudType:arcelType&, Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar) const [with CloudType = Foam::KinematicCloud<Foam::Cloud<Foam::KinematicPa rcel<Foam:article> > >, typename CloudType:arcelType = Foam::KinematicParcel<Foam:article>, Foam::scalar = double]’:
parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:49:1: instantiated from here
lnInclude/newForce.C:82:5: error: no match for ‘operator=’ in ‘value.Foam::forceSuSp::Su() = D’
lnInclude/newForce.C:82:5: note: candidate is:
/opt/openfoam211/src/OpenFOAM/lnInclude/Vector.H:58:7: note: Foam::Vector<double>& Foam::Vector<double>:perator=(const Foam::Vector<double>&)
/opt/openfoam211/src/OpenFOAM/lnInclude/Vector.H:58:7: note: no known conversion for argument 1 from ‘Foam::dimensionedVector {aka Foam::dimensioned<Foam::Vector<double> >}’ to ‘const Foam::Vector<double>&’
make: *** [Make/linux64GccDPOpt/makeBasicKinematicParcelSubmodels.o] Error 1
mayank@mayank-Precision-WorkStation-T3400:~/OpenFOAM/mayank-2.1.1/platforms/linux64GccDPOpt/src/lagrangian/incompressible/intermediate$
How to apply Transport Equation on DPM Scalars? yuhai FLUENT 0 May 19, 2010 11:38
generic scalars in star manuutin STAR-CD 0 August 7, 2009 07:05
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 06:49
about .run file and information of scalars isidro Siemens 0 March 11, 2004 12:37
The Field Scalars in Tascflow Darcy CFX 0 November 19, 2003 23:14
