-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Turbine Siting Case, FOAM FATAL ERROR (https://www.cfd-online.com/Forums/openfoam-solving/129274-turbine-siting-case-foam-fatal-error.html)
JMRF February 1, 2014 11:04
I'm new in OpenFOAM and I'm trying to run the Turbine Siting Case, wich is in the directory tutorials/incompressible/simpleFoam/TurbineSiting.
So far I have run the executable Allrun, and then simpleFoam; but when I execute the simpleFoam comand I get this:
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.2-9240f8b967db
Exec : simpleFoam
Date : Feb 01 2014
Time : 09:39:42
Host : "jmrf-Lenovo-U310"
PID : 16097
Case : /home/jmrf/OpenFOAM/jmrf-2.2.2/run/tutorials/incompressible/simpleFoam/turbineSiting
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 252
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.11;
Creating fintite volume options from fvOptions
Selecting finite volume options model type actuationDiskSource
Source: disk1
- applying source for all time
- selecting cells using cellSet actuationDisk1
--> FOAM FATAL ERROR:
Cannot find directory "polyMesh/sets" in times 252 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 142.
FOAM exiting
What am I doing wrong?
Regards,
Juan
