Computing mass flow rate on an arbitrary plane
Old   February 9, 2014, 18:05
Default Computing mass flow rate on an arbitrary plane
jvc
Jamie Canino
jvc is on a distinguished road
I need to compute the mass flow rate for a compressible unsteady flow through an arbitrary plane in my computational domain at each time step. I can compute the mass flow rate at a boundary fairly easily using
patchName = runTime.controlDict().lookupOrDefault<word>("inlet Name","inlet");
label patchIn = mesh.boundaryMesh().findPatchID(patchName);
scalar massflow = Foam::sum(rhoPhi.boundaryField()[patchID]);
Foam::reduce(massflow, sumOp<scalar>());
My problem is how to find the cells in the domain that I want without having a patch. Is there a way to define a "fake" patch just for post-processing? I'm running a solver that is based on interPhaseChangeFoam.
Thanks for the help.
jvc is offline   Reply With Quote
Old   February 9, 2014, 19:43
HECKMANN Frédéric
fredo490 is on a distinguished road
A while ago I did this with EnSight but is was a post-treatment.
fredo490 is online now   Reply With Quote
Old   February 9, 2014, 20:16
jvc
Jamie Canino
Since I need the mass flow rate every time step (or at least every few time steps) I was hoping there would be a way to do it without post-processing.
Old   February 10, 2014, 03:39
HECKMANN Frédéric
As far as I know, many people have asked the same question (for years) and none has found a solution. If you really want to do it, you will have to code it from scratch
Otherwise you can try to create an "interior patch" like Fluent has.
EnSight can do it with a little effort and I guess once it is set up, it will work for all time steps.
Old   February 10, 2014, 03:55
phil
gelbebanane is on a distinguished road
i solved it that way:
Install "swak4foam"
and then add this to your "controlDict"
functions
  //MASSENDURCHSATZ
  massFlow
      type patchMassFlow;
     functionObjectLibs
         "libsimpleFunctionObjects.so"
     verbose true;
     patches
         inlet
         outlet
     factor 1.;
edit the patches and you are done. You will get a post processing folder containing a file with the mass flows for each timestep live.
gelbebanane is offline   Reply With Quote
Old   February 10, 2014, 06:05
HECKMANN Frédéric
The problem remain the same... Your code only works for a "patch".
Old   February 10, 2014, 09:16
Joachim Herb
jherb is on a distinguished road
Have a look at this thesis:
http://brage.bibsys.no/uis/bitstream...unn%20Elin.pdf
and search for createSampledSurface
There is a special section about sampling on surfaces (if I understood it correctly also inside the flow domain).
jherb is offline   Reply With Quote
mass flow rate
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
Mass Flow rate through a plane titio OpenFOAM Post-Processing 9 August 22, 2017 03:46
Calculation of mass flow rate through a plane titio OpenFOAM Post-Processing 2 September 28, 2010 00:28
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
