Relative residuals for solid solver doesnot converge for fsiFoam |
June 4, 2019, 17:05 |
Aashay Tinaikar
Rep Power: 6 |
I am using fsiFoam with foam-extend 4.0. I am trying to setup an fsi simulation on the same lines as 3dTube example case.
Even if the problem is very similar to the example, it is not going beyond 1st iteration itself. The relative residuals for solid solver does not go beyond 0.99 and I am not sure why. I ran checkmesh on both of my geometries and all the quality checks are passed. You could also have a look at my fsiProperties, result log file if needed. I have tried with different values of relaxation factors too, but none of it seem to work. As far as the solid mesh is concerned, I have generated it from the fluid patch by using extrudeMesh command. I have extruded such that it has only 1 cell in its thickness. Please help me if you could figure out any mistakes in my settings. Any form of guidance will help me a lot. |
June 28, 2022, 23:22 |
the displacement iteration in fsifoam does not converge
wegner liu
Hi, using foam-extend4.0 and fsifoam toolkit, I have encountered the same problem as you. Solving for Dx Dy Dz does not converge and the error appears as " Floating point exception (core dumped)". Besides, the " current fsi under-relaxation factor" is huge.
The mesh should be okay since I followed the exact steps proposed here: http://www.tfd.chalmers.se/~hani/kur...er_reviewd.pdf Has anyone met (and solved) the problem yet? Some information is listed here. 1. the pointD BC: Code:
boundaryField { RUBLADEsolid { type calculated; value uniform (0 0 0); } RUHUB { type fixedValue; value uniform (0 0 0); } RUSHROUD { type fixedValue; value uniform (0 0 0); } } Code:
boundaryField { RUBLADEsolid { type tractionDisplacement; traction uniform ( 0 0 0 ); pressure uniform 0; value uniform (0 0 0); } RUHUB { type fixedDisplacement; value uniform (0 0 0); } RUSHROUD { type fixedDisplacement; value uniform (0 0 0); } } Code:
planeStress no; rheology { type linearElastic; rho rho [1 -3 0 0 0 0 0] 100000; E E [1 -1 -2 0 0 0 0] 5e10; nu nu [0 0 0 0 0 0 0] 0.4; } Code:
Time = 0.0001, iteration: 1 Current fsi under-relaxation factor: 0.05 Creating accumulated fluid interface displacement Maximal accumulated displacement of interface points: 0 GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1 Evolving fluid solver: consistentIcoFluid Courant Number mean: 7.12736e-19 max: 0.01 velocity magnitude: 0.5 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.94034e-07, No Iterations 7 DILUPBiCG: Solving for Uy, Initial residual = 0.999998, Final residual = 3.73936e-07, No Iterations 7 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.39304e-07, No Iterations 8 GAMG: Solving for p, Initial residual = 1, Final residual = 9.27349e-07, No Iterations 20 GAMG: Solving for p, Initial residual = 0.0723483, Final residual = 4.49518e-07, No Iterations 14 time step continuity errors : sum local = 5.78997e-09, global = -7.55275e-10 GAMG: Solving for p, Initial residual = 0.0748816, Final residual = 9.65041e-07, No Iterations 14 GAMG: Solving for p, Initial residual = 0.0440953, Final residual = 4.29407e-07, No Iterations 12 time step continuity errors : sum local = 4.87308e-09, global = 5.35554e-10 GAMG: Solving for p, Initial residual = 0.0400866, Final residual = 6.38266e-07, No Iterations 13 GAMG: Solving for p, Initial residual = 0.024472, Final residual = 4.43531e-07, No Iterations 13 time step continuity errors : sum local = 3.89512e-09, global = 6.78701e-10 Setting traction on solid patch Total force (fluid) = (-0.0134068 621.105 627.723) Total force (solid) = (0.0134591 -567.936 -604.765) Evolving solid solver: unsTotalLagrangianSolid Creating residual output file Time: 0.0001, outer iteration: 0 DICPCG: Solving for Dx, Initial residual = 1, Final residual = 0.0791076, No Iterations 9 DICPCG: Solving for Dy, Initial residual = 1, Final residual = 0.066415, No Iterations 5 DICPCG: Solving for Dz, Initial residual = 1, Final residual = 0.0746411, No Iterations 8 Relative residual = 1 Time: 0.0001, outer iteration: 1 DICPCG: Solving for Dx, Initial residual = 0.999848, Final residual = 0.0609168, No Iterations 4 DICPCG: Solving for Dy, Initial residual = 0.152375, Final residual = 0.011218, No Iterations 7 DICPCG: Solving for Dz, Initial residual = 0.142506, Final residual = 0.013695, No Iterations 7 Relative residual = 0.460105 Time: 0.0001, outer iteration: 2 ... ... Time: 0.0001, outer iteration: 198 DICPCG: Solving for Dx, Initial residual = 0.80369, Final residual = 0.00909372, No Iterations 1 DICPCG: Solving for Dy, Initial residual = 0.851155, Final residual = 0.00412858, No Iterations 1 DICPCG: Solving for Dz, Initial residual = 0.82635, Final residual = 0.00559023, No Iterations 1 Relative residual = 1.01305 Time: 0.0001, outer iteration: 199 DICPCG: Solving for Dx, Initial residual = 0.798573, Final residual = 0.0108907, No Iterations 1 DICPCG: Solving for Dy, Initial residual = 0.837254, Final residual = 0.00392149, No Iterations 1 DICPCG: Solving for Dz, Initial residual = 0.810311, Final residual = 0.00622592, No Iterations 1 Relative residual = 1.01913 DICPCG: Solving for D, Initial residula = 1, Final residual = 0.837254, No outer iterations = 200 Max relative residual = 1.19353, Relative residual = 1.01913, enforceLinear = 0 Current fsi relative residual norm: 1 Alternative fsi residual: 1 Time = 0.0001, iteration: 2 Current fsi under-relaxation factor: 0.05 Maximal accumulated displacement of interface points: 2.78575e+142 GAMG: Solving for cellMotionUx, Initial residual = 1, Final residual = 0.000512934, No Iterations 3 GAMG: Solving for cellMotionUy, Initial residual = 1, Final residual = 0.000721874, No Iterations 4 GAMG: Solving for cellMotionUz, Initial residual = 1, Final residual = 0.000722922, No Iterations 3 GAMG: Solving for cellMotionUx, Initial residual = 0.0429526, Final residual = 2.57213e-05, No Iterations 7 GAMG: Solving for cellMotionUy, Initial residual = 0.0268615, Final residual = 2.15803e-05, No Iterations 6 GAMG: Solving for cellMotionUz, Initial residual = 0.0283927, Final residual = 1.53445e-05, No Iterations 6 Floating point exception (core dumped) Last edited by wegner; June 28, 2022 at 23:47. Reason: format problem |
fsifoam |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Mesh size and solver residuals... | Scott | CFX | 5 | December 15, 2008 17:10 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
solver settings, residuals plateau for a long time | Mumawalde | CFX | 2 | December 17, 2007 08:49 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
