manualInjection model in sprayFoam
Old   March 27, 2014, 06:42
Default manualInjection model in sprayFoam
Mentalo is on a distinguished road
i'm trying to use the manualInjection model with the sprayFoam Solver. Unfortunately the simulation crashes prior the first iteration.
This is the corresponding error message:
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.x-0f3a889dd39b
Exec   : sprayFoam
Date   : Mar 27 2014
Time   : 11:35:58
Host   : "philipp-Home"
PID    : 5779
Case   : /home/philipp/cfd/OF_22x/EtF1/full_Spray_EtF1_8
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Creating combustion model
Selecting combustion model PaSR<psiChemistryCombustion>
Selecting chemistry type
    chemistrySolver ode;
    chemistryThermo psi;
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
Selecting chemistryReader chemkinReader
Reading CHEMKIN thermo data in new file format
chemistryModel: Number of species = 5 and reactions = 1
Selecting ODE solver SIBS
Creating component thermo properties:
    multi-component carrier - 5 species
    liquids - 1 components
    solids - 0 components
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
    alphaK1         0.85034;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.85616;
    Prt             1;
    gamma1          0.5532;
    gamma2          0.4403;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Creating field dpdt
Creating field kinetic energy K
No finite volume options present
Constructing reacting cloud
Constructing particle forces
    Selecting particle force sphereDrag
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model manualInjection
    Constructing 3-D injection
Selecting distribution model RosinRammler
Selecting dispersion model none
Selecting patch interaction model standardWallInteraction
Selecting surface film model none
Selecting U integration scheme Euler
Selecting heat transfer model RanzMarshall
Selecting T integration scheme analytical
Selecting composition model singlePhaseMixture
Selecting phase change model liquidEvaporationBoil
Participating liquid species:
    C2H5OH
Selecting AtomizationModel none
Selecting BreakupModel ReitzDiwakar
Selecting StochasticCollisionModel none
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
 in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/sprayFoam"
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
My sprayCloudProperties file looks like this:
|  \\    /   O peration     | Version:  2.2.0                                 |
FoamFile
    version     2.0;
    format      binary;
    class       dictionary;
    location    "constant";
    object      SprayCloudProperties;
solution
    active          true;
    coupled         true;
    transient       yes;
    cellValueSourceCorrection on;
    sourceTerms
        schemes
            rho             explicit 1;
            U               explicit 1;
            Yi              explicit 1;
            h               explicit 1;
            radiation       explicit 1;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        thermo:mu       cell;
        T               cell;
        Cp              cell;
        p               cell;
    kappa           cell;
    integrationSchemes
        U               Euler;
        T               analytical;
constantProperties
    T0              294;
    // place holders for rho0 and Cp0 - reset from liquid props using T0
    rho0            1000;
    Cp0             4187;
    youngsModulus   1e9;
    poissonsRatio   0.35;
    epsilon0        1;
    f0              0.5;
    Pr              0.7;
    Tvap            273;
    Tbp             351;
    constantVolume  false;
subModels
    particleForces
        sphereDrag;
    injectionModels
        model1
        type            manualInjection;  //coneNozzleInjection;
            massTotal       1.25e-4;
            parcelBasisType mass;
            SOI             0;
            positionsFile   "reactingCloud1Positions";
            U0              (0 0 0);
            //injectionMethod disc;
            //flowType        constantVelocity;
        //UMag            0;
            //outerDiameter   2.0e-4;
            //innerDiameter   0;
            //duration        0.1;
            //position        ( 0 0 -0.215 );
            //direction       ( 0 0 1 );
            //parcelsPerSecond 900000;
        //flowRateProfile constant 1;
        //velocityProfile constant 0;
            //Cd              constant 0.9;
            //thetaInner      constant 0.0;
            //thetaOuter      constant 10.0;
            sizeDistribution
                type        RosinRammler;
                RosinRammlerDistribution
                    minValue        1e-06;
                    maxValue        0.00015;
                    d               0.00015;
                    n               3;
    injectionModel manualInjection;
    dispersionModel none;
    patchInteractionModel standardWallInteraction;
    heatTransferModel RanzMarshall;
    compositionModel singlePhaseMixture;
    phaseChangeModel liquidEvaporationBoil;
    surfaceFilmModel none;
    atomizationModel none;
    breakupModel    ReitzDiwakar; // ReitzKHRT;
    stochasticCollisionModel none;
    radiation       off;
    standardWallInteractionCoeffs
        type            rebound;
    RanzMarshallCoeffs
        BirdCorrection  true;
    singlePhaseMixtureCoeffs
        phases
            liquid
                C2H5OH               1;
    liquidEvaporationBoilCoeffs
        enthalpyTransfer enthalpyDifference;
        activeLiquids    ( C2H5OH );
    ReitzDiwakarCoeffs
        solveOscillationEq yes;
        Cbag            6;
        Cb              0.785;
        Cstrip          0.5;
        Cs              10;
    ReitzKHRTCoeffs
        B0              0.61;
        B1              40;
        Ctau            1;
        CRT             0.1;
        msLimit         0.2;
        WeberLimit      6;
    TABCoeffs
        y0              0;
        yDot0           0;
        Cmu             10;
        Comega          8;
        WeCrit          12;
cloudFunctions
Does someone have an idea whats this about? Help is appreciated.
Regards
Mentalo is offline   Reply With Quote
Old   April 2, 2014, 10:29
Ananda Kannan
ansubru is on a distinguished road
Hi!!
If I were you, I would first run the case using the debug build of openfoam. You would get a much better insight into the origin of the error.
Regards
ansubru
ansubru is offline   Reply With Quote
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 11:23
Mixture model + VOF? blacksoil2012 Fluent Multiphase 2 February 9, 2014 00:59
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 10:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
