GPU in openFoam
Like Tree4Likes
  • 4 Post By wyldckat
Old   February 23, 2014, 06:47
Default GPU in openFoam
30na is on a distinguished road
Hi, I'm simulating a 3-D case in parallel using MrfInterFoam . but it's taking so long abd my instructor told me to get familiar with GPU running and run the program usuing this methos.
So could you help me with this matter and explain how to run programs in openFOAm with GPU . any help would be apperciates.
30na is offline   Reply With Quote
Old   February 23, 2014, 06:58
ArathoN
ArathoN is on a distinguished road
you need to have a cuda enabled gpu (an nvidia) then install cufflink and the latest extend version.
http://www.extend-project.de/
https://code.google.com/p/cufflink-library/
ArathoN is offline   Reply With Quote
Old   March 2, 2014, 08:51
Default GPU for OpenFOAM
Hi everybody ,
I'm kinda new to OpenFOAM and I'm running a 3D case using MRFInterFoam , but it's taking too long and I've been informed that I can process my case much faster using GPU. I googled it but didn't find anything useful , can anyone give me some advice on how to install GPU for OpenFOAM ( i think it's a plug-in) , if you could give me a link it would be great.
and also if there is a tutorial on how to install and run a program with GPU i would be really grateful ! I'm really stuck ! Thanks in advance !
Old   March 2, 2014, 09:57
Retired Super Moderator
Bruno Santos
Greetings to all!
@30na: I've moved your post latest post to this thread, since you're the one who created it.
I've compiled today a page that lists the known available solutions: http://openfoamwiki.net/index.php/GPGPU
But keep in mind that if you don't have a really powerful GPU card (e.g. NVidia Tesla and Kepler), you're better off using multiple CPUs.
The easiest solution at this moment is to install foam-extend 3.0: http://wikki.gridcore.se/foam-extend/download
If you want more than one version of OpenFOAM working in your machine, read this page: http://openfoamwiki.net/index.php/In...with_the_Shell
Best regards,
Bruno
Old   December 5, 2014, 07:10
Bazinga is on a distinguished road
Is there any solution at the moment to use a NVIDIA Tesla K80 with OpenFOAM simulations that is free and uses double precision?
Bazinga is offline   Reply With Quote
Old   December 5, 2014, 08:13
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can compile Symscape's GPU solver library (http://www.symscape.com/gpu-1-1-openfoam) with double precision. Though the process is not quite pleasant, and you need to correct CMakeLists.txt files.
alexeym is offline   Reply With Quote
Old   April 13, 2015, 16:44
Oskar Grochowalski
newoscar is on a distinguished road
There is also RapidCFD - an open source project.
RapidCFD solvers can be used the same way as solvers in OpenFOAM. If you are familiar with the latter, you will find it easy to use.
The only thing that can be treated either as inconvenience or as easily adjustable is that you have to compile it by yourself. The whole process is described on wiki site of the project.
newoscar is offline   Reply With Quote
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
Problem on Installing Gpu plugin for OpenFOAM on RHEL-5.1 nagendra verma OpenFOAM 1 March 2, 2013 09:05
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
