Dam break tutorial - transportProperties issue
Old   February 27, 2014, 06:53
Default Dam break tutorial - transportProperties issue
Guillaume Ducrue
Guimloute is on a distinguished road
Dear Foamers,
I was doing the dam break tutorial when I met an issue at the interFoam running :
Reading transportProperties
--> FOAM FATAL IO ERROR:
keyword phases is undefined in dictionary "xxxxx/run/damBreak/constant/transportProperties"
file: xxxxx/run/damBreak/constant/transportProperties from line 20 to line 62.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
I have tried to identifies what is missing without success so far. I cannot find any reference to a phases keyword in any of the configuration files.
Here is my transportProperties, as it was in the original tutorial folder :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phase1 // water
    transportModel  Newtonian;
    nu              nu [ 0 2 -1 0 0 0 0 ] 1e-06;
    rho             rho [ 1 -3 0 0 0 0 0 ] 1000;
    CrossPowerLawCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
        nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
        m               m [ 0 0 1 0 0 0 0 ] 1;
        n               n [ 0 0 0 0 0 0 0 ] 0;
    BirdCarreauCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
        k               k [ 0 0 1 0 0 0 0 ] 99.6;
        n               n [ 0 0 0 0 0 0 0 ] 0.1003;
phase2 // air
    nu              nu [ 0 2 -1 0 0 0 0 ] 1.48e-05;
    rho             rho [ 1 -3 0 0 0 0 0 ] 1;
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
sigma           sigma [ 1 0 -2 0 0 0 0 ] 0.07;
Anyone would have any idea on this issue ?
Thanks.
Guimloute is offline   Reply With Quote
Old   February 27, 2014, 07:13
Default tutorial files not up to date
Guillaume Ducrue
Sorry for the disturbance,
I found the source of the problem. The files in my /home directory had not been updated when I upgraded OpenFOAM to 2.3.0.
Thus, in my transportProperties file this line was missing at the beginning :
phases (phase1 phase2);
So here the lesson I learned today : always check that the tutorial files in my /home folder are up-to-date.
Old   February 27, 2014, 07:14
Pablo Higuera
Phicau is on a distinguished road
version 2.3 introduces a new convention to define the phases. You no longer call them phase1 and phase2, but you now can use their physical name (e.g. water, air...) and afterwards you define them:
phases (water air);
Best,
Pablo
Phicau is offline   Reply With Quote
Old   February 27, 2014, 08:02
Guillaume Ducrue
Thank you Pablo !
It is easier that way.
Old   June 27, 2017, 11:52
Default damTempBreak
Cláudio Corrêa
claudiocor is on a distinguished road
Dears,
I build new solver from interFoam inserting the temperatura equation I compiled no erros but when I ues tutorial case damBreak for validation the follow erros appears
| \\ / O peration | Version: 4.1 |
| \\/ M anipulation | |
Build : 4.1
Exec : interTempFoam
Date : Jun 27 2017
Time : 12:49:11
Host : "claudio-300E4C"
PID : 22926
Case : /home/claudiocorrea/OpenFOAM/claudiocorrea-4.1/run/damTempBreak
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field T
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:bjectRegistry::modified() const at ??:?
#4 Foam:bjectRegistry::modified() const at ??:?
#5 Foam::Time::readModifiedObjects() at ??:?
#6 Foam::Time::run() const at Time.C:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
I introduce the required features for temperature in the tutorial.
Can anybody help me?
claudiocor is offline   Reply With Quote
Stability Issue with interDyMFoam / floatingObject tutorial ccmccomb OpenFOAM Running, Solving & CFD 4 April 27, 2023 04:13
Multi-Component mixture modeling issue FlowMe STAR-CCM+ 10 March 12, 2016 12:43
[Other] issue 1_running several mesh configurations for a cavity model (tutorial) Luis Batista OpenFOAM Meshing & Mesh Conversion 2 March 24, 2013 18:24
dam break problem tharem OpenFOAM 11 December 14, 2011 11:15
interDyMFoam mass conservation issues - dam break tutorial kmooney OpenFOAM 5 June 1, 2010 14:23
