February 27, 2014, 12:58 |
MapField warning for 3D mesh
Ye Zhang
Rep Power: 16 |
Dear all,
I want to do a 3D unsteady simulation begin with steady state solution. So I want to mapField my steady solution to unsteady case. The are both the same mesh. But when I run the command It gives a lot of warning shown below: I also checked the mapped result with paraview, nothing happens. Any idea?? PS: There is cyclicAMI interface BC in my model. -------------- FOAM Warning : From function Foam::List<Foam::tetIndices> Foam:olyMeshTetDecomposition::faceTetIndices(con st polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 480071, 4(118649 43440 43439 118650), produces a valid tet decomposition. -------------- Best regards, Ye |
February 27, 2014, 14:14 |
as you've got identical meshes did you use -consistent flag for mapFields? |
February 27, 2014, 18:21 |
Ye Zhang
Rep Power: 16 |
Hi Alexey
I did use -consistent flag for mapField. The command is like this: "mapField ../xxx -sourceTime latestTime -consistent" Best regards Ye |
March 12, 2014, 05:14 |
Ye Zhang
Rep Power: 16 |
Hi Alexey
Do you have any idea to solve this problem? Best regards, Ye |
March 12, 2014, 05:19 |
if you got really identical geometries and BCs, maybe it'll be easier just to copy latest time folder from one simulation to 0 folder of the other? |
March 12, 2014, 11:07 |
Ye Zhang
Rep Power: 16 |
Yes, that is an solution.
I just want to find out the problem anyway, thank you! Ye |
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 19:50 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
