DPMFoam case worked perfectly in the first run but crashes in every subsequent run!! |
March 11, 2014, 10:33 |
Ananda Kannan
Rep Power: 12 |
Good day fellow foamers!!
I had posted in this forum earlier, and about the same issue I am going to report now. http://www.cfd-online.com/Forums/ope...nadequacy.html I have been trying to simulate "Specific gravity aided separation of grains" on a vibrating table. I have just began my work and started with setting up a very simple case of a fluidized system i.e a rectangular box being filled with spherical grains from the top and fluidized slightly from the bottom (quite similar to the Goldschmidt tutorial case). I believed that the error had been fixed when I re-checked and corrected my set-up and that was definitely true. I was successfully able to parallelize and simulate my set-up for up to 5500 particles. However, when I re-run the same test case (duplicated all the requisite files) in parallel with a reduced number of particles (only 200 to reduce computation time), the simulation crashes after a run time of 0.023 sec. This is the same simulation which run for almost 3 secs the last time I ran it. I have no logical idea as to why this is happening.. This is the stack trace of my case (OF 2.3.0 64-bit Ubuntu 12.04 LTS debug mode) Code:
Evolving kinematicCloud Solving 3-D cloud kinematicCloud 489 move-collide subCycles Cloud: kinematicCloud Current number of parcels = 200 Current mass in system = 0.00211618 Linear momentum = (0.0211626 0.00478364 0.00267929) |Linear momentum| = 0.0218613 Linear kinetic energy = 2.92399 model1: number of parcels added = 200 mass introduced = 0.00211618 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) : patch top - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch bottom - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch walls - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch frontAndBack - escape = 0, 0 - stick = 0, 0 Rotational kinetic energy = 0.135396 smoothSolver: Solving for U.airx, Initial residual = 0.672366, Final residual = 7.73413e-06, No Iterations 34 smoothSolver: Solving for U.airy, Initial residual = 0.67905, Final residual = 8.42677e-06, No Iterations 37 smoothSolver: Solving for U.airz, Initial residual = 0.566016, Final residual = 8.79127e-06, No Iterations 33 GAMG: Solving for p, Initial residual = 0.426701, Final residual = 0.00386942, No Iterations 7 time step continuity errors : sum local = 1.30166, global = -0.0290894, cumulative = -0.249577 GAMG: Solving for p, Initial residual = 0.177388, Final residual = 7.62761e-07, No Iterations 22 time step continuity errors : sum local = 0.000521, global = 5.96277e-05, cumulative = -0.249517 ExecutionTime = 138.63 s ClockTime = 138 s Courant Number mean: 596.86 max: 5746.98 Time = 0.023 Evolving kinematicCloud Solving 3-D cloud kinematicCloud 478 move-collide subCycles [2] #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/printStack.C:221 [2] #1 Foam::sigFpe::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/signals/sigFpe.C:108 [2] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 Foam::divideOp3<double, double, double>::operator()(double const&, double const&) const at ~/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/ops.H:167 [2] #4 void VectorSpaceOps<3, 0>::opVS<Foam::Vector<double>, Foam::VectorSpace<Foam::Vector<double>, double, 3>, double, Foam::divideOp3<double, double, double> >(Foam::Vector<double>&, Foam::VectorSpace<Foam::Vector<double>, double, 3> const&, double const&, Foam::divideOp3<double, double, double>) at ~/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/VectorSpaceM.H:34 [2] #5 Foam::Vector<double> Foam::operator/<Foam::Vector<double>, double, 3>(Foam::VectorSpace<Foam::Vector<double>, double, 3> const&, double) at ~/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/VectorSpaceI.H:587 [2] #6 Foam::PairCollision<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >::wallInteraction() at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/PairCollision.C:249 [2] #7 Foam::PairCollision<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >::collide() at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/PairCollision.C:671 [2] #8 [2] at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/CollidingCloud.C:66 [2] #9 [2] at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/CollidingCloud.C:224 [2] #10 [2] at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/KinematicCloud.C:204 [2] #11 [2] at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/KinematicCloud.C:112 [2] #12 [2] at ~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/CollidingCloud.C:197 [2] #13 [2] at ~/OpenFOAM/ask-2.3.0/Solvers/DPMFoam_mod/DPMFoam_mod.C:85 [2] #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #15 [2] in "/home/ask/OpenFOAM/ask-2.3.0/platforms/linux64GccDPDebug/bin/DPMFoam_mod" [ask-HP-Z230-Tower-Workstation:03979] *** Process received signal *** [ask-HP-Z230-Tower-Workstation:03979] Signal: Floating point exception (8) [ask-HP-Z230-Tower-Workstation:03979] Signal code: (-6) [ask-HP-Z230-Tower-Workstation:03979] Failing at address: 0x3e800000f8b [ask-HP-Z230-Tower-Workstation:03979] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f8fce3544a0] [ask-HP-Z230-Tower-Workstation:03979] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f8fce354425] [ask-HP-Z230-Tower-Workstation:03979] [ 2] /home/ask/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/lib/libOpenFOAM.so(_ZN4Foam6sigFpe10sigHandlerEi+0xbc) [0x7f8fcf81a7d0] [ask-HP-Z230-Tower-Workstation:03979] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f8fce3544a0] [ask-HP-Z230-Tower-Workstation:03979] [ 4] DPMFoam_mod(_ZNK4Foam9divideOp3IdddEclERKdS3_+0x20) [0x4c2624] [ask-HP-Z230-Tower-Workstation:03979] [ 5] DPMFoam_mod(_ZN14VectorSpaceOpsILi3ELi0EE4opVSIN4Foam6VectorIdEENS2_11VectorSpaceIS4_dLi3EEEdNS2_9divideOp3IdddEEEEvRT_RKT0_RKT1_T2_+0x29) [0x4abac7] [ask-HP-Z230-Tower-Workstation:03979] [ 6] DPMFoam_mod(_ZN4FoamdvINS_6VectorIdEEdLi3EEET_RKNS_11VectorSpaceIS3_T0_XT1_EEEd+0x3c) [0x49cc75] [ask-HP-Z230-Tower-Workstation:03979] [ 7] /home/ask/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/lib/liblagrangianIntermediate.so(_ZN4Foam13PairCollisionINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEEE15wallInteractionEv+0x3f6) [0x7f8fd28f6ea4] [ask-HP-Z230-Tower-Workstation:03979] [ 8] /home/ask/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/lib/liblagrangianIntermediate.so(_ZN4Foam13PairCollisionINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEEE7collideEv+0x30) [0x7f8fd28e644a] [ask-HP-Z230-Tower-Workstation:03979] [ 9] DPMFoam_mod() [0x4f69e6] [ask-HP-Z230-Tower-Workstation:03979] [10] DPMFoam_mod() [0x4e1b81] [ask-HP-Z230-Tower-Workstation:03979] [11] DPMFoam_mod() [0x4cc701] [ask-HP-Z230-Tower-Workstation:03979] [12] DPMFoam_mod() [0x4b6dd4] [ask-HP-Z230-Tower-Workstation:03979] [13] DPMFoam_mod() [0x4a388e] [ask-HP-Z230-Tower-Workstation:03979] [14] DPMFoam_mod() [0x493a8d] [ask-HP-Z230-Tower-Workstation:03979] [15] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f8fce33f76d] [ask-HP-Z230-Tower-Workstation:03979] [16] DPMFoam_mod() [0x492239] [ask-HP-Z230-Tower-Workstation:03979] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 3979 on node ask-HP-Z230-Tower-Workstation exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- Moreover, What I dont really understand is how can a simulation which ran perfectly the first time, crash in each of the several subsequent runs??? Any ideas anyone??? This issue is just bugging me?? Best regards ansubru Last edited by wyldckat; March 11, 2014 at 14:37. Reason: Added [CODE][/CODE] |
March 11, 2014, 14:49 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi ansubru,
This seems to be a Lagrangian type solver and these solvers usually rely heavily in random numbers for randomly introducing new particles and for particles directions/collisions (if I'm not mistaken). Therefore, it's somehwat easy for you to be able to have a case that works fine with 5500 particles and not with 5499 or 5501. As for the error message, it's indicating that there is a division that is triggering a sigFpe: http://en.wikipedia.org/wiki/SIGFPE#SIGFPE Since you're using the debugging build, it tells you to then have a look into the file "~/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/intermediate/lnInclude/PairCollision.C", line 249, where the division is being requested. The code in question seems to be this one: Code:
vector pW = nearPt - pos; scalar normalAlignment = normal & pW/mag(pW); This is assuming that you did not change the source code on this file. Best regards, Bruno PS: Please post code and solver output following these instructions: Posting code and output with [CODE]
March 12, 2014, 02:33 |
Ananda Kannan
Rep Power: 12 |
Thanks a lot Bruno!! You have given me a new direction to look in. I will try to develop along those lines. As I had told you I am rather new to the forum so, Thank you so much for your earnest support. I will post here further if there are any developments.
PS - I have not altered the source code in any manner, however I am using a duplicated version of the solver DPMFoam entitled DPMFoam_mod (the code is exactly the same, i just felt that it would be safer to use my own copy of the solver so that accidental deletions are not affected at the src) |
March 13, 2014, 03:32 |
Ananda Kannan
Rep Power: 12 |
Hi again Bruno!!
Well, I have tried a lot of things to try to overcome this error.. I included this snippet of code (experimental of course, and I am pretty sure this is not the right way ) to try to circumvent this error, however I have not managed to do so.. Code:
if (nearest.distance() < r) { vector normal = mesh.faceAreas()[realFaceI]; if (mag(normal) == 0) { normal = (normal)/1.0; } else { normal /= mag(normal); } const vector& nearPt = nearest.rawPoint(); vector pW = nearPt - pos; // experimental bug fix if (mag(pW) == 0) { scalar normalAlignment = normal & pW; } else { scalar normalAlignment = normal & pW;//mag(pW); } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; // --> isn't the dimensions of pressure [1 -1 -2 0 0 0 0]; I am really quite befuddled by this issue . Do you have any more ideas??? Thanks again!! ansubru |
March 13, 2014, 13:33 |
Wouter van der Meer
hello ansubru,
As you can see in line 11 of the header, this file is binary, so probably you told the solver in controlDict to write in binary. If you change this to ASCII then you get a lot bigger files but you can read them. Hope this helps Wouter |
March 15, 2014, 03:23 |
#6 | |
Bruno Santos
Rep Power: 128 |
Greetings to all!
A few suggestions:
Best regards, Bruno
March 17, 2014, 04:27 |
Ananda Kannan
Rep Power: 12 |
Hi again Bruno!!
Thanks for that added insight!! I had already figured out something based on those lines (i.e. overlapping between positions).. I have however, got my case to run again flawlessly.. I realized that the bounding walls within my geometry were quite close to each other.. hence there was a good probability that a particle that rebounded off the bottom wall would occupy a cell in the top wall where another particle was already situated... This is not my application at all... in the actual set up, there are no bounding walls on the top... hence i changed my geometry to eliminate the presence of the top wall i.e. push it to infinitum ( ideally i do not want particles to strike this wall).. when i made this change in geometry (top wall distance 10X longest distance in my geometry...) my case did run smoothly without any issues... Thanks gain for your invaluable support!! Regards ansubru PS - I am not using OF 2.3.x yet... |
use batch mode to run an unsteady case | PaulineP | FLUENT | 9 | April 4, 2019 08:18 |
Flux update during an MPI run between decomposed case parts? | scott | OpenFOAM | 0 | July 21, 2010 20:47 |
Restart of case crashes | feijooos | OpenFOAM Running, Solving & CFD | 0 | July 21, 2009 11:04 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
How to run and save tranisent case on Cray XD1 | Leon | FLUENT | 0 | October 3, 2006 21:59 |
