oscillating 2D drop mesh convergence
Old   June 2, 2020, 22:52
Default oscillating 2D drop mesh convergence
Josh McCraney
joshmccraney is on a distinguished road
Hi FOAMers!
I am running interFoam version 6. I am looking at an inviscid 2D drop of water in air with zero g. I give the drop a slight disturbance, which causes the drop to oscillate back to equilibrium. When I perform a mesh-convergence study, the results for dx = 40 and 100 are much closer to the analytic prediction than dx = 200: why? I have a limit on the max Courant number, so I don't think it's a time step issue. What do you think?
For your consideration, my controlDict looks like this
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.02;//1000;
deltaT          0.000000001; // INITIAL TIME STEP
writeControl    adjustableRunTime;
writeInterval   0.0002;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.2;
maxAlphaCo      0.2;
maxDeltaT       1;//0.0000025;
functions
    waterVolume
        type            volFieldValue;
        libs            ("libfieldFunctionObjects.so");
        log             true;
        writeControl    writeTime;
        writeFields     true;
        regionType      all;
        operation       volIntegrate;
        fields
            alpha.water
Thanks for everything!
joshmccraney is offline   Reply With Quote
Old   July 11, 2020, 05:25
eco
magnushaese is on a distinguished road
I have two suggestions, convergence-wise. I assume this is laminar, thus U-p coupling only with the calculation of the liquid fraction via the MULES solver.
1. As for MULES, you might want to check independence of its subcycles i.e.nAlphaSubCycles and nAlphaCorr.
2. Also more general. It seems like you chose a convective CFL~0. 2 driven solution. I assume you might use the PISO mode at this time step. However, I would recommend lowering the initial linear solver residuals more restrict each time step, thus using the PIMPLE framework to guarantee independence of residuum and a successive lowering of the inital residuums of from 1e-5 down to 1e-8 or so.
magnushaese is offline   Reply With Quote
Poor convergence: just mesh or numerics? piotr.mecht OpenFOAM 10 May 12, 2020 11:05
Increase in pressure drop when refine the mesh Thromkar FLUENT 4 December 5, 2018 14:13
[Other] Generating Mesh for a drop in another fluid Prosper OpenFOAM Meshing & Mesh Conversion 10 October 19, 2017 02:27
Force can not converge colopolo CFX 13 October 4, 2011 22:03
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
