[Waves2foam] alpha1 file
Old   March 18, 2014, 17:35
Default [Waves2foam] alpha1 file
Ellie is on a distinguished road
Hi Foamers,
I am working on the Waves2foam package, and trying to add an (floating) object inside the geometry of the standingwave case using snappyHexMesh. Then I met a few problems. One problem that I am dealing with is as below.
I want to modify the 'alpha1' file to increase the size of the internalField due to the result of snappyhexMesh, but i have no idea what's the rule for creating an alpha file or if it can be created automatically. Is there anyone who can help? Thanks in advance.
Ellie
Reading g
Reading waveProperties
Reading field p_rgh
Reading field alpha1
--> FOAM FATAL IO ERROR:
size 400000 is not equal to the given value of 1547000
file: /home/fgong/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/waves2Foam/tutorials/waveFoam/motorBikeWavePractice/0/alpha1 from line 18 to line 400556.
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/fgong/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
Ellie is offline   Reply With Quote
Old   March 19, 2014, 14:56
It's lucky that I already know what's the problem and solution.
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
