March 19, 2014, 05:39
Philipp Reinhold
okay, i think i,ve got the right settings in the snappyhexmeshdict now, but i get a floating point exception now after 2 timesteps.. can anybody help me?
i have to finish this study in a few weeks
Iteration 2
Moving mesh using displacement scaling : min:0.5625 max:0.5625
Checking faces in error :
non-orthogonality > 65 degrees : 0
faces with face pyramid volume < 1e-13 : 6
faces with face-decomposition tet quality < 1e-30 : 0
faces with concavity > 80 degrees : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0..1) < 0.02 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.02 : 0
faces on cells with determinant < 0.001 : 0
Iteration 3
Moving mesh using displacement scaling : min:0.421875 max:0.421875
Iteration 4
Moving mesh using displacement scaling : min:0.316406 max:0.316406
Iteration 5
Displacement scaling for error reduction set to 0.
Moving mesh using displacement scaling : min:0.237305 max:0.237305
Iteration 6
Moving mesh using displacement scaling : min:0 max:0
faces with face pyramid volume < 1e-13 : 0
Successfully moved mesh
Moved mesh in = 0 s
Morph iteration 9
Calculating patchDisplacement as distance to nearest surface point ...
Wanted displacement : average:0.000209065 min:0.000173982 max:0.000234267
Calculated surface displacement in = 0 s
Overriding displacement on features :
implicit features : false
explicit features : true
multi-patch features : false
Stringing feature edges : changed 2 points
Stringing feature edges : changed 0 points
Attraction:
linear : max:(4.33681e-19 1.84314e-17 -0.000173982) avg:(5.42101e-20 5.50233e-18 -0.000209065)
feature : max:(0 1.47451e-17 0) avg:(-0.000360237 1.55854e-18 -6.80867e-05)
Feature analysis : total points:8 attraction to :
feature point : 0
feature edge : 4
nearest surface : 0
rest : 4
--> FOAM Warning : Displacement (-0.000540986 -5.52943e-18 -9.83649e-05) at mesh point 0 coord (0.00108197 0.00190512 0.00019673) points through the surrounding patch faces
Smoothing displacement ...
Iteration 0
Iteration 10
Iteration 20
Displacement smoothed in = 0 s
Moving mesh ...
Iteration 0
Moving mesh using displacement scaling : min:1 max:1
Iteration 1
Moving mesh using displacement scaling : min:0.75 max:0.75
Iteration 2
Iteration 3
Iteration 4
Iteration 5
Iteration 6
Moved mesh in = 0 s
Repatching faces according to nearest surface ...
Repatched 0 faces in = 0 s
Edge intersection testing:
Number of edges : 6
Number of edges to retest : 6
Number of intersected edges : 0
Merging 0 sets of faces.
No faces merged ...
Merging all points on surface that
- are used by only two boundary faces and
- make an angle with a cosine of more than 0.866025.
No straight edges simplified and no points removed ...
Snapped mesh : cells:1 faces:6 points:8
Cells per refinement level:
0 0
1 0
2 0
3 0
4 0
5 0
6 1
Writing mesh to time 2
Wrote mesh in = 0 s.
Mesh snapped in = 0.05 s.
Layer thickness specified as final layer and expansion ratio.
Shrinking and layer addition phase
Using mesh parameters
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
Merging all faces of a cell
- which are on the same patch
- which make an angle < 60 degrees
(cos:0.5)
- as long as the resulting face doesn't become concave by more than 90 degrees
(0=straight, 180=fully concave)
No faces merged ...
- make an angle with a cosine of more than 0.5.
Checking mesh manifoldness ...
Checking initial mesh ...
Detected 0 illegal faces (concave, zero area or negative cell pyramid volume)
Adding in total 0 inter-processor patches to handle extrusion of non-manifold processor boundaries.
Constructing mesh displacer ...
Handling points with inconsistent layer specification ...
Handling non-manifold points ...
Checking patch manifoldness ...
Outside of local patch is multiply connected across edges or points at 0 points.
Set displacement to zero for all 0 non-manifold points
Handling feature edges ...
Handling cells with warped patch faces ...
Set displacement to zero on 0 warped faces since layer would be > 0.5 of the size of the bounding box.
patch faces layers avg thickness[m]
near-wall overall
lowerWall 0 1 0 0
runde_rueckfoerderstruktur_ascii 6 1 4.07e-06 4.07e-06
medialAxisSmoothingInfo : Calculate distance to Medial Axis ...
shrinkMeshDistance : Smoothing normals ...
Iteration 0 residual 0.553
Inserting points on patch frontAndBack if angle to nearest layer patch > 30 degrees.
Inserting points on patch inlet if angle to nearest layer patch > 30 degrees.
Inserting points on patch outlet if angle to nearest layer patch > 30 degrees.
Inserting points on patch upperWall if angle to nearest layer patch > 30 degrees.
shrinkMeshDistance : Smoothing normals in interior ...
Iteration 0 residual 0.361
Layer addition iteration 0
Prevented extrusion on 0 coupled patch points during syncPatchDisplacement.
Determining displacement for added points according to pointNormal ...
No valid normal for point 0 (0.00108 0.00191 0.000197); setting displacement to (2.8e-06 -2.85e-06 7.59e-07)
No valid normal for point 4 (0.00108 0.00214 0.000197); setting displacement to (2.8e-06 2.85e-06 7.59e-07)
No valid normal for point 3 (0.0009 0.00191 0.000174); setting displacement to (-2.02e-06 -3.17e-06 1.55e-06)
No valid normal for point 5 (0.0009 0.00214 0.000174); setting displacement to (-2.02e-06 3.17e-06 1.55e-06)
Displacement at illegal point (0.00108 0.00191 0.000197) set to (-7.06e-05 8.69e-05 6.93e-06)
Displacement at illegal point (0.00108 0.00214 0.000197) set to (-9.51e-05 -5.7e-05 8.98e-06)
Displacement at illegal point (0.0009 0.00191 0.000174) set to (6.41e-05 0.000119 3.07e-05)
Displacement at illegal point (0.0009 0.00214 0.000174) set to (7.79e-05 -6.86e-05 4.12e-05)
shrinkMeshMedialDistance : Smoothing using Medial Axis ...
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::autoLayerDriver::shrinkMeshMedialDistance(Foam::motionSmoother&, Foam::dictionary const&, Foam::List<Foam::Pair<int> > const&, int, double, int, int, double, Foam::Field<double> const&, Foam::Field<double> const&, Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh> const&, Foam::GeometricField<double, Foam::pointPatchField, Foam::pointMesh> const&, Foam::GeometricField<double, Foam::pointPatchField, Foam::pointMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh> const&, Foam::List<Foam::autoLayerDriver::extrudeMode>&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&) const in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libautoMesh.so"
#4 Foam::autoLayerDriver::addLayers(Foam::layerParameters const&, Foam::dictionary const&, Foam::List<int> const&, int, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libautoMesh.so"
#5 Foam::autoLayerDriver::doLayers(Foam::dictionary const&, Foam::dictionary const&, Foam::layerParameters const&, bool, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libautoMesh.so"
in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/snappyHexMesh"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
thank you
