Simple gas flow through pipe
Like Tree1Likes
  • 1 Post By mikeR
Old   April 2, 2014, 08:26
Default Simple gas flow through pipe
anonymous
mikeR is on a distinguished road
Hi CFD-Community!
I'm very new to cfd simulations, especially I just started with openFoam. I'm kinda stuck on probably the most basic examples using icoFoam, maybe someone can spot my stupid mistake
Minimal test case: A simple small rectangular capillary - internal pressure 0.1Pa - with a pressure inlet on one side. It is assumed that there is an infinite volume with with a fixed pressure of 1000Pa connected to the inlet so we can assume there will be a constant flow into the capillary (for simplicity I assume the pressure is equal to the kinematic pressure).
The simulation is running without errors but when I view the data in paraFoam I would assume that after some time the pressure within the capillary should reach 1000Pa. This is however not the case, the pressure is somewhere in the magnitude of 1xE-16.
My p file:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.1;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 1000;
    Walls
        type            zeroGradient;
My U file:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Inlet
        type            pressureInletVelocity ;
        value           uniform (0 0 0);
    Walls
        type            zeroGradient;
In my blockMeshDict is specified the Inlet type as Wall
Inlet
    type wall;
Is this in general the right approach for the problem? Any tips are greatly appreciated
mikeR is offline   Reply With Quote
Old   April 4, 2014, 10:20
anonymous
so I think I solved my problem. In the end it was a problem with the mesh, can't really tell what it was but using netgen and converting it instead of using blockMesh solved everything
Annier likes this.
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 11:33
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 16:53
