Convergence problem with flow facing a backstep
Old   January 19, 2013, 17:42
Default Convergence problem with flow facing a backstep (case files now attached)
David
GM_XIII is on a distinguished road
I am starting with OpenFoam so this can be a silly question. I have experience with other CFD programs but i decide to start learning OpenFoam.
Problem data: Incompressible airfoil facing a backstep, Steady, I am using the icoFoam solver.
I have convergence problems as the Courant goes up as the residuals.
Feel free to ask for further information and thanks in advance.
GM_XIII is offline   Reply With Quote
Old   January 21, 2013, 23:23
Eric Robertson
msuaeronautics is on a distinguished road
Can we see your output file?
msuaeronautics is offline   Reply With Quote
Old   January 22, 2013, 05:10
Max Meinicke
maxmeinicke is on a distinguished road
icoFoam is a transient solver. You can identify that under:
<OPENFOAM_DIR>/applications/solvers/incompressible/icoFoam/icoFoam.C line 58 (OF-2.1.x)
fvm::ddt(U) -> transient
So you must not set steadyState ddtSchemes in system/fvSchemes. For example: use full implicit Euler scheme.
Search the following folder for all available ddtSchemes:
<OPENFOAM_DIR>/src/finiteVolume/finiteVolume/ddtSchemes
To identify their name for fvSchemes, have a look into their header files (*.H). Search for the string in TypeName. That's what you can put into fvSchemes.
Example:
EulerDdtScheme.H
line 71 (OF-2.1.x):
TypeName("Euler");
ddtSchemes
default Euler;
maxmeinicke is offline   Reply With Quote
Old   January 22, 2013, 08:02
David
Thank you, I thought that a transient solver could manage steady cases with that fvShemes, my fault of couse. I would like to do it Steady becouse if i do it transient i need to set a very low time step in order to keep the coutant number low. So, what's the best solver to solve this case as Steady?
Old   January 22, 2013, 09:29
Max Meinicke
Use simpleFoam. It has the following properties:
- steady state
  • no fvm::ddt in UEqn.H, which means
  • ddt == 0
- incompressible
  • rho == constant, not solving for rho
  • pressure p is not the real pressure in [N/m2], but it is p / rho [m2/s2]
- time step
  • important: it does not matter which deltaT you select; as best you select dT = 1s
  • convergence is reached with relaxation factors in fvSolution
Old   January 22, 2013, 10:24
Aathavan
Aadhavan is on a distinguished road
Hi Maxmeinicke,
I have a small silly question,
[ pressure p is not the real pressure in [N/m2], but it is p / rho [m2/s2] ]
according your post, to get the real pressure in [N/m2], what should we do?
how to convert the simpleFoam simulation pressure in to real pressure????
I am bit confused by the unit of (p/rho ---> m2/s2), can you please explain about it?
Thanks,
Aadhavan
Aadhavan is offline   Reply With Quote
Old   January 22, 2013, 10:45
David
Thank you mate, I finally did it I haven't realised that you could use a turbulent solver and then specify that the case is laminar. Now it is done, I will upload the case files in case someone could be interested.
Old   January 22, 2013, 13:22
Max Meinicke
Congratulations to you
unit calculation:
compressible:
p = F / A = N / m2 = kg * m / s2 / m2 = kg / m / s2
OpenFOAM notation: 'dimensions [1 -1 -2 0 0 0 0];'
incompressible:
p / rho = F / A / rho = N / m2 / (kg / m3) = kg * m / s2 / m2 / (kg / m3) = m2 / s2
OpenFOAM notation: 'dimensions [0 2 -2 0 0 0 0];'
Have a look into the pressure boundary files in time folder 0 for incompressible and compressible tutorial cases.
unit explanation:
In OpenFOAM basic solvers, 'incompressible' means constant density and 'compressible' means the density varies. So in compressible solvers a density transport equation is solved (rhoEqn). If the density is constant, you can divide all terms in the transport equations by the density. You will find out that the density is removed from all terms except the pressure term and the viscosity term. That is why with compressible and incompressible solvers one must be careful with units.
compressible uses:
  • pressure p [Pa]
  • dynamic viscosity mu (greek letter) [kg / m / s]
incompressible uses:
  • pressure p which is actually p / rho [m2 / s2]
  • kinematic viscosity nu (greek letter) [m2 / s]
Connection between units:
p_compr = p_incompr * rho
mu_compr = nu_incompr * rho
As you can see, the units scale with rho. So if you calculate water, mu is 1000 times larger than nu.
To calculate the real pressure for an incompressible solver, multiply with the density. If I would like to write the real pressure to the timefolders, I would derive a new solver and add a new volScalarField p_real.
If someone knows, how to manage writing the real pressure for incompressible solvers to time folders using functions and without creating a new solver, please let us know.
If you have more questions, please ask.
which OF version do you use?
Old   January 23, 2013, 02:47
Aathavan
Thanks for your long reply, I am using OF-2.0.1.
small correction your explanation,
pressure p which is actually p / rho [m2 / m2],
this should be (m2/s2).
Thanks,
Aadhavan
Old   January 23, 2013, 05:52
Max Meinicke
I've created a new solver simpleFoam2.
It is derived from simpleFoam and outputs the real pressure pReal.
just extract the file and read the README...
Old   January 28, 2013, 21:54
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, this paper is useful
http://www.cimec.org.ar/ojs/index.ph...File/3263/3186
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
santiagomarquezd is offline   Reply With Quote
Old   January 29, 2013, 01:43
Aathavan
Hi Santiag,
Can you please say something about it. I tried to look at it but I am not able.
It seems it is in French or some other language.
is there any English version.
Thanks,
Aadhavan
Old   January 29, 2013, 03:16
akidess's Avatar
Anton Kidess
I opened Santiago's link and got an English PDF.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 26, 2014, 02:55
CFDUser
CFDUser_ is on a distinguished road
can you tel me the boundary conditions for this problem.
I also would like to see your result, may be velocity contort is quiet enough. can you post here?
CFDUser_ is offline   Reply With Quote
Old   March 27, 2014, 03:56
David
It is my mot have uploaded it when i finished it, now it would be hard to find it but if i do i will upload it. By the way, i think i might not change the BC of my initial case, which is uploaded. I. Think i use velocity inlet+ presure outlet (0 pressure).
Regards
Modeling unsteady multiphase flow in porous media - convergence problem Vaibhav Kumar Main CFD Forum 1 July 22, 2012 04:32
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
simpleFoam convergence problems for pipe flow problem Mike Graham OpenFOAM Running, Solving & CFD 0 January 30, 2012 14:40
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 15:18
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
