velocity U in the Calculator- Problem
Old   March 21, 2014, 19:10
Default velocity U in the Calculator- Problem
ziehjay
sanjar is on a distinguished road
Hey guys,
i am working with the tool calculator in paraview right now. Unfortunately it does not accept my U as a scalar value, when i want to integrate the velocity U in my calculation.
This error occurs:
ERROR: In /home/sanjar/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/Charts/vtkPlotPoints.cxx, line 641
vtkPlotLine (0xdc0b280): No Y column is set (index 1).
Does somebody has an answer or a suggestion how to fix this problem?
Background of this problem:
http://www.cfd-online.com/Forums/ope...-paraview.html
thank you guys and thanks for every helping suggestion!!
sanjar is offline   Reply With Quote
Old   March 24, 2014, 12:49
ziehjay
hey guys, anybody out there who could say what the problem might be..?
still couldnt figure it out :/
thanks!
Old   March 25, 2014, 08:26
ziehjay
hey guys,
i thought it would make sense if i explain and show you the things i did so far to solve my problem.
AIM: get the same plots like the ones from ANSYS (see pic 1)
1. typed into calculator the formular p + (0.5*997.561*(UČ))
- 997.561 is the density of water
- U is my veloocity, but it did not work because calculator did not accept the scalar, so i just typed in my starting velocity at the inlet 13 m/s
--> Result: got a plot like in pic 2,3,4
--> Problem: all three plots do not start from 0 respectivey from a negative point like in ANSYS, because i used 13, 9 and 5,4 m/s and not the scalar
2. tried to check if a got velocity on my plate of my geometry, there is no velocity
--> looking: http://www.cfd-online.com/Forums/ope...-paraview.html
changed my BCs from --> to
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 -5.4 0);
boundaryField
    WALL
        type            fixedValue;
        value           uniform (0 0 0); --> (0 -5.4 0)
    OUTLET
        type            pressureInletOutletVelocity;
    EROSIONPLATE
        type            fixedValue;
    INLET
        type            fixedValue;
now i got the velocity on my plate which is constantly 5,4; 9 and 13 m/s
but i generate such plots if i use calculator and the vector U_Y or even the normal velocity of 5.4 m/s (see pic 5)
I really dont know where my problem is?
if there is somebody who could help me, please spend some minutes and explain/show it to me..its pretty important!
thanks!
File Type: jpg Bildschirmfoto vom 2014-03-25 14:24:24.jpg (47.5 KB, 5 views)
Old   March 25, 2014, 13:38
Joachim Herb
jherb is on a distinguished road
Do you plot the velocity on a wall? Then it is set by the boundary conditions to be 0. So the result is correct. Are your boundary conditions the same in ANSYS and OpenFOAM? It looks like you might be using free slip conditions in ANSYS and no slip in OpenFOAM for that wall? Can you post your 0/U file of OpenFOAM and (parts of) the ccl file of Ansys (if you use CFX)?
jherb is offline   Reply With Quote
Old   March 25, 2014, 13:47
ziehjay
hello,
no i plo the velocity on the plate, where the flow is sprinkling on. (i uploaded a pic which i made in paint a long time ago :-) )
above your post there is my 0/U file.
i dont think that it has something to do with the BCs in OF and in ANSYS because my plot in OF has the same peak (maximum) like the one in ANSYS.
the problem for me is the y- axis (y-achsenschnittstelle) because it does not start with 0 but with a higher value. and this value comes from the formule i use in the calculator, which you can see above.
i tried to plot just the normal pressure (relativdruck, also ohne diese formel) and this one was right because it also starts from negative y-axis but i dont reach the peaks.
so all in all, it has smething to do with the problem that i cant use my scalar AND vector U in the calculator. Both doesnt work.
thank you for your attention.
Old   March 25, 2014, 16:10
ziehjay
nevertheless joachim,
i am still looking forward for new suggestions!
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
