January 16, 2016, 07:21 |
Error with freestream BC
Rep Power: 13 |
i want to model an aerated tank with a degassing outlet. I read in the forum that this can be achieved by using the freestream BC, however if i specify in U.air the outlet patch as : outlet { type freestream; } i get the error message "keyword freestreamValue is undefined in dictionary /xxx/0/U.air.boundaryField.outlet" when using twoPhaseEulerFoam solver. What does this mean? I'm using OF 3.0.1. Thanks a lot! |
April 19, 2016, 15:33 |
Rep Power: 10 |
Bumping this, I'm running into a similar error. It looks like there was a variable change from 2.X->3.0 but I'm not sure what the correction is
edit: Passing it both freestreamValue and value worked. This is my nut file but U is similar. Code:
boundaryField { airfoil { type fixedValue; value uniform 0.014; } frontback { type empty; } inlet { type freestream; freestreamValue uniform 0.014; value uniform 0.014; } outlet { type freestream; freestreamValue uniform 0.014; value uniform 0.014; } topbottom { type freestream; freestreamValue uniform 0.014; value uniform 0.014; } } |
April 21, 2016, 10:11 |
Hi ss32,
I am also trying degassing outlet. Can simply use Slip BC for the liquid and pressureInletOutletVelocity BC for the gas at the degassing patch? |
multi-species plasma test case | jentink | SU2 | 6 | August 5, 2016 02:04 |
SU2 cfg file and runtime problems | hedley | SU2 | 19 | January 26, 2016 04:17 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
singularity? | mihaipruna | OpenFOAM Running, Solving & CFD | 5 | April 24, 2012 17:18 |
modeling freestream in an big Volume with gravity | Raambi | STAR-CCM+ | 1 | May 10, 2011 07:04 |
