divergence after 35 msec with reactingFoam
Like Tree1Likes
  • 1 Post By jherb
Old   April 7, 2014, 12:30
Default divergence after 35 msec with reactingFoam
Bobby
babakflame is on a distinguished road
Dear Foamers
I am trying to simulate a swirl flame (SM1) with reactingFoam solver (LES-FSD approach).
I have made a 3D grid wich has a compression ratio of 3.5 i.e. the last cell near the outlet has a length 3.5 times to the first cell after nozzle outlet. The latest cells have length of 1.2 mm and the first cells immediately after the nozzle outlet have the length of 0.34 mm. Also, I have used immersed bounadry conditions to make the inlet flows fully developped.
My problem is that divergence symptoms appear in the result after 30 msec.
My courant number was 0.39.
I have used the zeroGradient condition for the outelet velocity.
I have attached two pics from my velocity results one showing the flowfield at 30 msec and the other identifies velocity after 33 msec.
As It is evident the divergence symptoms appear from the outlet of the doamin.
Would Somebody PLZ hint me why this happens and how can I solve it?
PS: I reduced the courant number to 0.35 and the problem still exists.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   April 8, 2014, 17:04
Joachim Herb
jherb is on a distinguished road
What do you use as boundary condition for the pressure field? Perhaps "meanValue" instead of fixedValue does help.
jherb is offline   Reply With Quote
Old   April 9, 2014, 04:10
Bobby
Greetings Joachim
These are my input files for pressure and velocity. As it is evident from the figures the disturbance comes into the domain from outlet. I have treated side (lateral boundaries) as an outlet too. detacher is the wall between inletAir and inletSwirl flows.
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    inletFuel
        type            zeroGradient;
    inletAir
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 101325;
    bluffbody
        type            zeroGradient;
    detacher
        type            zeroGradient;
    side
        type            fixedValue;
    inletSwirl
        type            zeroGradient;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 20 0);
boundaryField
    outlet
        type            zeroGradient;
    side
        type            zeroGradient;
    bluffbody
        type            fixedValue;
        value           uniform (0 0 0);
    detacher
        type            fixedValue;
    inletAir
        type          turbulentInlet;
        referenceField   uniform (0 20 0);
        fluctuationScale (0.02 0.1 0.02);
    value            uniform (0 20 0);
    inletFuel
        referenceField   uniform (0 32.7 0);
        fluctuationScale (0.04 0.2 0.04);
    value            uniform (0 32.7 0);
    inletSwirl
        type          swirlFlowRateInletVelocity;
        flowRate         0.0107;
        rpm              6632.42;
Would you PLZ introduce an example in tutorials that uses meanValue?
Regards
Bobi
Old   April 9, 2014, 10:38
Joachim Herb
I think there is not example in the tutorials for meanValue. But you can look at the documentation in the header of https://github.com/OpenFOAM/OpenFOAM...FvPatchField.H and this thread: http://www.cfd-online.com/Forums/ope...condition.html
babakflame likes this.
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 03:44
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
