problem with "running in parallel" >> error
hello! I was trying to run in PARALLEL icoFoam but me the following error occurred: Anyone know what I should do to correct the error? Thank you.
observation: I have a core i7 (8 cores) s@s-Aspire-V371:~/Dropbox//icoFoam/cavity$ mpirun -np 8 icoFoam -parallel > log & [1] 17678 s@s-Aspire-V3-571:~/Dropbox/Openfoam_PG/tutorials/incompressible/icoFoam/cavity$ [0] [0] [0] --> FOAM FATAL ERROR: [0] Cannot read "/home/s/Dropbox/Openfoam_PG/tutorials/incompressible/icoFoam/cavity/system/decomposeParDict" [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 17679 on node s-Aspire-V3-571 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- |
Greetings Vitor,
What message do you get if you run the following command? Code:
ls -l /home/s/Dropbox/Openfoam_PG/tutorials/incompressible/icoFoam/cavity/system/decomposeParDict Bruno |
ls -l /home/s/Dropbox/Openfoam_PG/tutorials/incompressible/icoFoam/cavity/system/decomposeParDictclear Quote:
I just type blockMesh and then ran icoFoam in parallel like above
before running a case in parallel you have to decompose it with decomposePar utility. This utility reads system/decomposeParDict for the number of domains and decomposition method. You can find an example of the file in (for example ;)) $FOAM_TUTORIALS/multiphase/interFoam/ras/damBreak/system. And the sequence of commands for your case should be Code:
$ blockMesh |
thanks bro... I got success!
