assert |
April 25, 2014 08:48 |
cannot find file constant/boundaryData/outlet/points
When I run 'sonicFoam' I get the error:
cannot find file MyFolder/constant/boundaryData/outlet/points at line 0.
I checked my parameter files for 'outlet/points' and other clues that an additional file is needed. Googling supplied me no additional hints either, so I hope it is a too-easy-to-put-online question.
Can someone help me out? Thanks!
Below I post the full error message, followed by files I think are most relevant:
## Calling sonicFoam
## Response
| \\ / O peration | Version: 2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 2.1-88b2f2ae3a0b
Exec : sonicfoam
Date : Apr 25 2014
Time : 13:59:34
Host : "AIRBEAR-W7-I5"
PID : 5072
Case : D:/Airbearing/cpp/build-SchmeshCreator-Desktop_Qt_5_1_1_MinGW_32bit-Deb
ug
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMas
ter
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<spec
ieThermo<eConstThermo<perfectGas>>>>>
--> FOAM FATAL IO ERROR:
cannot find file
file: MyFolder/constant/boundaryData/outlet/points at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
## 0/alphat
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
side_CW
type zeroGradient;
side_CCW
type zeroGradient;
defaultFaces
type compressible::alphatWallFunction;
value uniform 0;
## 0/p
FoamFile
version 2.0;
format ascii;
location "0";
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1.7e5;
boundaryField
inlet
type timeVaryingMappedFixedValue;
setAverage 1;
fileName "pIn";
outOfBounds clamp;
outlet
setAverage 1;
fileName "pOut";
outOfBounds clamp;
side_CW
type zeroGradient;
side_CCW
type zeroGradient;
defaultFaces
type zeroGradient;
## 0/T
FoamFile
version 2.0;
format ascii;
location "0";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 293;
boundaryField
inlet
type fixedValue;
value uniform 293;
outlet
type zeroGradient;
side_CW
type zeroGradient;
side_CCW
type zeroGradient;
defaultFaces
type zeroGradient;
## 0/U
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
side_CW
type slip;
side_CCW
type slip;
defaultFaces
type fixedValue;
value uniform (0 0 0);
## constant/thermophysicalProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType ePsiThermo<pureMixture<sutherlandTransport<specieThermo<eConstThermo<perfectGas>>>>>;
mixture air 1 28.9 717 0 1.458e-6 110.4;
## constant/polyMesh/boundary
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant\polyMesh";
object boundary;
5
side_CW
type zeroGradient;
nFaces 16;
startFace 3625;
side_CCW
type zeroGradient;
nFaces 16;
startFace 3641;
outlet
type outletInlet;
nFaces 208;
startFace 3657;
inlet
type outletInlet;
nFaces 16;
startFace 3865;
defaultFaces
type zeroGradient;
nFaces 1034;
startFace 3881;
## constant/polyMesh/faces
FoamFile
{ version 2.0;
format ascii;
class faceList;
location "constant/polyMesh";
object faces;
4915
4(1322 1323 1355 1354)
4(1322 1368 1369 1323)
3(1354 1368 1322)
4(496 539 540 497)
3(496 652 539)
3(947 956 898)
## constant/polyMesh/neighbour
FoamFile
{ version 2.0;
format ascii;
class labelList;
note "nPoints: 1407 nCells: 1708 nFaces: 4915";
object neighbour;
4915
14
16
649
-1
-1
-1
## constant/polyMesh/owner
FoamFile
{ version 2.0;
format ascii;
class labelList;
object owner;
4915
0
0
0
1706
1706
1707
## constant/polyMesh/points
FoamFile
{ version 2.0;
format ascii;
class vectorField;
object points;
1407
(-0.021651 0.012500000000000001 0)
(-0.021651 0.012500000000000001 0.00025000000000000001)
(-0.021651 0.012500000000000001 0.00050000000000000001)
(0.021651 0.012500000000000001 0.00050000000000000001)
(0.021651 0.012500000000000001 0.00075000000000000002)
(0.021651 0.012500000000000001 0.001)
## constant/polyMesh/sets/nonOrthoFaces
FoamFile
version 2.0;
format ascii;
class faceSet;
location "constant/polyMesh/sets";
object nonOrthoFaces;
40
2688
3009
3458
3006
1918
1598
## constant/turbulenceProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType RASModel;
## system/controlDict
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application sonicFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 0.007;
deltaT 1e-008;
writeControl adjustableRunTime;
writeInterval 1e-006;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep no;
## system/fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,e) Gauss limitedLinear 1;
div(phid,p) Gauss limitedLinear 1;
div(phi,K) Gauss limitedLinear 1;
div(phiv,p) Gauss limitedLinear 1;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
## system/fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
