air flow impinge on a hot cylinder
Old   April 28, 2014, 03:10
Default air flow impinge on a hot cylinder
dbnrop is on a distinguished road
I have a problem with a simulation. The flow configuration is as follows:
An air flow ( T = 298 K) impinge on a moving cylinder (T = 1873 K; u = 7 m/s). The boundaries around are no walls but rather open atmosphere. The aim is to detect a possible buoyancy flow because of the temperature differences. The air at the calculation area has a temperature about 323 K.
The solvers I chose are "rhoPimpleFoam" and "buoyantPimpleFoam".
First question: Are these the right solver or is there another better one?
The main problem affects the boundaries (to the atmosphere). I chose it as follows:
p:
boundary_to_atmosphere
type fixedValue; // OR type calculated;
value $internalField; // internalField is about 1e5
p_rgh:
type fixedFluxPressure;
value uniform 1e5;
T:
type inletOutlet;
value uniform 323;
inletValue uniform 323;
U:
type pressureInletOutletVelocity;
value uniform (0 0 0);
I think I did a mistake because I get a temperature lower than 273 at the internalField.
Second question: Are the boundaries correct?
Third question:
In the "thermophysicalProperties" I chose
thermoType
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;//sensibleInternalEnergy;//sensibleEnthalpy;
Is this correct for this type of flow?
I use OpenFoam 2.3.x
I hope somebody can help me.
Best regards,
dbnrop
dbnrop is offline   Reply With Quote
Old   April 28, 2014, 09:30
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by dbnrop View Post
p:
p_rgh:
value uniform 1e5;
T:
type inletOutlet;
value uniform 323;
U:
Third question:
thermoType
type heRhoThermo;
transport const;
thermo hConst;
specie specie;
Best regards,
dbnrop
I'm almost 100% positive buoyantPimpleFoam is the best for this. For the pressure I think you need
type calculated;
because p_rgh calculates pressure in the hotRoom example.
You would also need to setup probes (an example can be found in the TJunction tutorial in the controlDict file).
That's all I know.
massive_turbulence is offline   Reply With Quote
Modeling the air flow of an Internal Combustion Engine mateusdias89 CFX 21 September 23, 2015 08:22
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
