reactingFoam SandiaD_LTS tutorial error
Like Tree1Likes
  • 1 Post By kerim
Old   October 15, 2019, 23:01
Default reactingFoam SandiaD_LTS tutorial error
Fantastic Boy
kit607 is on a distinguished road
Hi all. I am using OpenFOAM 6 and I am trying the tutorial SandiaD_LTS. I just use the Allrun file to start the simulation without modifying any parameters. However, there is error for the setFields which shows below.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-fa1285188035
Exec   : setFields
Date   : Oct 16 2019
Time   : 10:47:04
Host   : "mgt-aaibe"
PID    : 30000
I/O    : uncollated
Case   : /home/mgt-aaibe/OpenFOAM/mgt-aaibe-6/run/combustion_test
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 1500
Reading setFieldsDict
Setting field default values
--> FOAM Warning :
    From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>]
    in file setFields.C at line 117
    Field T not found
--> FOAM Warning :
    Field N2 not found
--> FOAM Warning :
    Field O2 not found
--> FOAM Warning :
    Field CH4 not found
Setting field region values
    Adding cells with center within boxes 1((0 -10 -100) (0.0036 10 0))
--> FOAM Warning :
    Field CH4 not found
--> FOAM Warning :
    Field O2 not found
--> FOAM Warning :
    Field N2 not found
End
Is my installtion of OF got error or I miss out some step when I run the simulation? Thank you
kit607 is offline   Reply With Quote
Old   July 6, 2020, 18:13
Imed
Imed is on a distinguished road
Send a message via ICQ to Imed Send a message via AIM to Imed Send a message via Yahoo to Imed
hi there;
i had the same problem but I could fix it, if you still want fixing the problem I can help
Imed is offline   Reply With Quote
Old   December 6, 2020, 08:34
Haynes
h_kuriakose is on a distinguished road
I know, it's a late reply. But incase you need it, you can find the documentation and simulation files for Sandia D flame tutorial
https://www.cemf.ir/reactingfoam-how...e-by-openfoam/
h_kuriakose is offline   Reply With Quote
Old   December 6, 2020, 18:27
Imed
Hi;
Thank you very much for you replay, it is very useful thanks again.
Old   February 9, 2021, 08:09
serg
kont87 is on a distinguished road
Originally Posted by Imed View Post
hi there;
Hello! Could you help me? Having the same problem
Thanks in advance!
kont87 is offline   Reply With Quote
Old   December 6, 2021, 14:00
abdikerim kurbanaliev
kerim is on a distinguished road
Dear all. I am using OpenFOAM 7 and I am trying the tutorial SandiaD_LTS without any modification. I just used the Allrun file to start. But I have Floating point exception (core dumped) error after 3719 iteration.
Could you help me?
File Type: jpg Screenshot from 2021-12-07 00-57-11.jpg (134.8 KB, 17 views)
kerim is offline   Reply With Quote
Old   December 20, 2021, 18:19
Unhappy "cannot find patchField entry" problems for SandiaD_LTS
Uğur
ugata88 is on a distinguished road
Hello everyone, I am new to openfoam and need to simulate nonpremixed combustion in openfoam-9, for this ı select SandiaD_LTS solver
1 .I created axi-symmetric cylinder geometry for 2D case on Salome-Meca 2015, also used seperated small angle (3 degre) wedge planes,
2 .I created patchfiled for inletCH4 (patch), inletair(patch), outlet (patch), frontandBack_pos (wedge) ,frontandBack_neg (wedge)
3. for meshing I used Netgen 2d3d algorithm and 3d parameters hypotheses
4. Exporting .unv mesh file to openfoam
5. I used chemkinToFoam, ideasUnvToFoam, so that constant/polymesh file is appeared, checkMesh is OK ,
6. After that, I arranged system/setFieldsDict for initializing inletCH4 field and running reactinFoam, so I encountered the following message;
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for frontandBack_pos
file: /home/ugur/OpenFOAM/ugur-9/run/SandiaD_LTS/0/T/boundaryField from line 25 to line 52.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184.
FOAM exiting
about the message, also I selected wedge patch type for frontandBack_pos and frontandBack_neg in constant / polyMesh /boundary
6
inletCH4
type patch;
nFaces 7;
startFace 64411;
inletair
type patch;
nFaces 20;
startFace 64418;
outlet
type patch;
nFaces 27;
startFace 64438;
wallTube
type patch;
nFaces 593;
startFace 64465;
frontandBack_pos
type patch;
nFaces 12980;
startFace 65058;
frontandBack_neg
type patch;
nFaces 13215;
startFace 78038;
and, also I selected initial temperature for my boundaryField in 0/T , as like this ;
dimensions [0 0 0 1 0 0 0];
internalField uniform 295;
boundaryField
inletCH4
type fixedValue;
value uniform 295;
wallTube
type zeroGradient;
inletair
type fixedValue;
value uniform 295;
outlet
type zeroGradient;
frontAndBack_pos
type wedge;
frontAndBack_neg
type wedge;
I feel so helpless and tired. Does anyone have a solution for this issue or have encountered this type of problem?
Thank you for your help in advance.
ugata88 is offline   Reply With Quote
Old   January 11, 2022, 10:11
Julio Pieri
JulioPieri is on a distinguished road
FOAM exiting
6
inletCH4
type patch;
nFaces 7;
startFace 64411;
inletair
type patch;
nFaces 20;
startFace 64418;
outlet
type patch;
nFaces 27;
startFace 64438;
wallTube
type patch;
nFaces 593;
startFace 64465;
frontandBack_pos
type patch;
nFaces 12980;
startFace 65058;
frontandBack_neg
type patch;
nFaces 13215;
startFace 78038;
boundaryField
inletCH4
type fixedValue;
value uniform 295;
wallTube
type zeroGradient;
inletair
type fixedValue;
value uniform 295;
outlet
type zeroGradient;
frontAndBack_pos
type wedge;
frontAndBack_neg
type wedge;
Seems that you have a lower case problem there. Your mesh is defined with frontandBack_pos, while your BCs are frontAndBack_pos
JulioPieri is offline   Reply With Quote
Old   January 13, 2022, 07:24
Uğur
Julio, thanks for attention first of all, You're right, I realized latter. For meshing I used blockMesh utility instead of Salome, Netgen algorithm. Becasuse of this, I annihilated skewness and ortogonality problems. But, ı have a new problem about initial k-epsilon values
Old   January 13, 2022, 12:15
Julio Pieri
For that you check the OF user guide or other regular resources. There are typical calculations for that!
Old   January 26, 2022, 20:07
Sanjan
altair98 is on a distinguished road
Could you help me?
Were you able to solve this issue?
I am facing the same.
altair98 is offline   Reply With Quote
Old   January 27, 2022, 04:27
  #12
Unfortunately, I haven't solved this problem. The same situation with newer versions of OpenFOAM8 and OpenFOAM9. However, older versions work well!
Old   January 27, 2022, 08:40
Sanjan
Thank you for letting me know. Could you mention which version seems to work because OpenFOAM v6 did not produce accurate results as mentioned in Sandia Flame D OpenFoam tutorial case - bad result?
I wonder if a particular version produces accurate results.
Thank you again
Old   January 27, 2022, 09:40
Thank you again
There is no ignition in the OF6 standard tutorial. Please try another turbulence model, for example, RNG k-epsilon model.
altair98 likes this.
Old   January 27, 2022, 18:19
Sanjan
Running in OF7 with any other turbulence model produces good results as compared with experimental data from https://tnfworkshop.org/data-archive...edjet/ch4-air/
Thank you for your suggestions!
Old   January 28, 2022, 01:10
I'm glad to hear that. Good luck.
reactingfoam, tutorial
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
