1 Attachment(s)
Dear Bruno
Many thanks for your efforts. I removed last time step to check again at 0.1008569 and same thin happened. Also I tried with 0.1008569 and 0.100857 and I got the error as double scalar. I have attached the file you asked for. Log file is 203MB so after compression, it is still big enough and cannot be attached. However tomorrow I shall try to see in my Uni what other compression software we have. If I have something which can compress more, I shall reattach. Best Regards Imad |
Hi Imad,
Hopefully I've figured out what the problem is! And it's one of those really annoying ones at that... OK, in post #16 you have this: Code:
Time = 0.1011976 Then in post #18 you have the following details:
In addition, the file list you provided does not follow to a fixed deltaT, which I assume is because you used "writeControl clockTime" in the first run, which lead to the time folders you have at this moment. The solution should be crazy simple: edit the file "system/controlDict" and change the timePrecision entry to 7 or 8 or even 9. I do write every once in a while here on the forum that every single detail, no matter how insignificant if may seem, is a lot more important to OpenFOAM than we might want to believe! Best regards, Bruno |
Dear Bruno
I did not come back earlier because I have modified my controlDict and am waiting for simulations to run so that I can give you some sort of feedback. Still I am waiting. As soon as I see everything is okay which I expect it to be like you do, I shall advise. Thanks again Best Regards Imad |
Hi Bruno
I am experiencing same error. Code:
cannot find file Also, log file ends in Code:
"e533.27255" |
Hi Imad,
A few questions:
Hi Bruno
controlDict contents are Code:
application pisoFoam; Answer 3: Last time step uniform/time contents are below Code:
FoamFile Thanks for your efforts and time. Regards Imad |
Hi Imad,
I strongly advise you not to manually modify the time information in the time-related folders and files. Specially because you're using the time averaging procedure. Edit the file "system/controlDict" and change this line: Code:
timePrecision 6; Code:
timePrecision 8; Code:
timePrecision 9; Bruno |
Thanks Bruno
I apologize, I made writePrecision as 8 but not timePrecision by mistake. Anyways, I have corrected it. Hopefully it should work. I shall update you as soon as simulations run. Best Regards Imad |
Dear Bruno
Thanks, it has worked. Best Regards Imad |
With reference to my question at link at http://www.openfoam.org/mantisbt/view.php?id=1355#c3178 I will let that question at openfoam.org stay because I need to know why the software does not write more time steps after deleting the different time step. If we together figure out a way to solve it, I shall close the query myself. I know that solving all my questions is not your responsibility but in fact people like you take out your time to guide us. I have posted the same question with more description at the link http://www.cfd-online.com/Forums/ope...tml#post503586 If you can just go through it and advise, it would be great as it can save a lot of time. For your information, my job scheduler does not provide any warning as you mentioned. I use OpenFOAM 2.1.1. I cannot find "adjustTimeStep". Regards Imad |
Hi Imad,
I've answered your question in the other thread. As for the last statement on this post above: Quote:
You can find all tutorials that use this feature by running this command: Code:
find $FOAM_TUTORIALS -name controlDict | xargs grep -sl "adjustTimeStep" Best regards, Bruno |
cannot find file ....buoyantBoussinesqPimpleFoam/hotcy/hotcylinderm/0/T at line 0
Dear all,
I was trying to simulate flow through a cylinder. After run the blockMesh , I have run buoyantBoussinesqPimpleFoam. but it gave the error, -> FOAM FATAL IO ERROR: cannot find file file: /home/diana/OpenFOAM/diana-2.3.0/run/tutorials/heatTransfer/buoyantBoussinesqPimpleFoam/hotcylinderm/0/T at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Since I'm new in OpenFoam it is difficult to find why this is happening . please kind to help me |
It looks the T file does not exist in the 0 folder of your case. This is file needed to read the boundary conditions for the temperature fields and the values of temperature. Some tutorials in OpenFOAM-2.3.0 contain T.org which you can use a template for your problem. Regards, Franjo Quote:
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for rotatingWall1 file: /home/sumit/OpenFOAM/sumit-3.0.1/run/tutorials/incompressible/simpleFoam/generator/0/U.boundaryField from line 26 to line 75. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting rotatingWall2 { type fixedValue; value uniform (0 0 0); origin (0 0 0); axis (1 0 0); omega 83.73; } rotatingWall3 { type fixedValue; value uniform (0 0 0); origin (0 0 0); axis (1 0 0); omega 83.73; } rotatingWall1 { type fixedValue; value uniform (0 0 0); origin (0 0 0); axis (1 0 0); omega 83.73; } stuck at this error from few days....any solution:confused: |
My guess, without looking at the entire U file, is that you are missing a ; and/or a } somewhere. Cheers, Antimony |
i will check....thanks
i am facing the same problem
Reading waveProperties --> FOAM FATAL IO ERROR: cannot find file file: /home/user/OpenFOAM/user-2.4.0/run/waveFlume2/constant/waveProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73 how to slove this problem i am running wave2foam tutorial waveFlume |
OpenFOAM for Windows 16.06 (v2)
Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run $ tutorials/incompressible/icoFoam/elbow_tri -bash: tutorials/incompressible/icoFoam/elbow_tri: Is a directory Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run $ fluentMeshToFoam.exe elbow.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| |* OpenFOAM for Windows 16.06 (v1) *| |* Built by CFD Support, www.cfdsupport.com (based on Symscape). *| \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-3.0.x\platforms\cygwin64mingw-w64DPInt32Opt\bin\fluentMeshToFoam.exe elbow.msh Date : Jan 05 2017 Time : 18:11:14 Host : "ADITYA" PID : 3904 Case : C:/OpenFOAM/Aadhi-3.0.x/run nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: C:/OpenFOAM/Aadhi-3.0.x/run/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run $ |
I am trying to import a mesh from netgen to openfoam and getting the same problem you had when i use the command netgenNeutralToFoam. How did you manage to get around this error? My error -->FOAM FATAL IO ERROR cannot find file file: /home/ofuser/workingDir/openfoam-v1706/system/controlDict at line 0 I am in the openfoam-v1706 working directory when i do this. Thanks. |
