#41 |
alix cattermole
Rep Power: 9 ![]() |
Sorry that post was directed to rogibear.
#42 | |
James
I get this too (attempting to install openfoam 4.1 on CAElinux2013) At least I do sometimes...I've made it work too, but not sure how... The instructions for installing Openfoam4.1 on ubuntu 12.04 from the Openfoamwiki.net are the best to go by... the cMake wget line doesn't work, but you can use the script wyldcat put together doing the same thing from the openfoam 2.3.1 instructions "getCmake" --- I've made it work once, on re-attempts get this error... It's to do with the run path being wrong in bachrc? if someone can explain a bit more about what is going wrong and why, would really help.... I'll keep trying and post back if I find a good solution. Great stuff here, love what everyone is doing! Thanks again |
#43 | |
James
#44 | |
James
I get the same after compile from source of Openfoam 4.1 on Ubuntu 12.04... --> cannot find file file: /home/caelinux4/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 72. FOAM exiting ---- Will let you know when I have a solution |
#45 | |
katia
Rep Power: 8 ![]() |
#46 |
Retired Super Moderator
Bruno Santos
Rep Power: 129 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: The problem is that the solver was executed within the wrong folder... notice that there are 2 folders "system" within the path it complains about: "cube/system/system/controlDict"
The solution should be to go back to the case folder, instead of trying to run the command from within the "system" folder. You can go back to the previous folder by running this command: Code:
cd ..
#47 |
Akshay Ravi
#48 |
Jayanta Dhar
Rep Power: 0 ![]() |
jayanta@jayanta-OptiPlex-3020:~/foam/jayanta-8/run/plateHole$ solidDisplacementFoam
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : solidDisplacementFoam Date : Feb 11 2021 Time : 14:42:36 Host : "jayanta-OptiPlex-3020" PID : 3296 Case : /home/jayanta/foam/jayanta-8/run/plateHole nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading mechanical properties --> FOAM FATAL IO ERROR: cannot open file file: /home/jayanta/foam/jayanta-8/run/plateHole/constant/mechanicalProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 86. FOAM exiting |
#49 | |
Afshin Davarpanah
Rep Power: 5 ![]() |
Unfortunately, again I can't find this file cannot find file "C:/Afshin/InterfaceShapes/RectangularChannel/50/p" What's the problem???????? |
Display Modes | |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
