Using Turbulence Models
Old   May 5, 2014, 00:44
Default Using Turbulence Models
Syed Zahid
zahid is on a distinguished road
I am new to CFD and OF, i am doing simulation of a fuselage. I am confused about which turbulence model to be used..?? And at what conditions one should use them...??
Can anyone clearly explain this...
Thanks.
zahid is offline   Reply With Quote
Old   May 5, 2014, 04:25
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by zahid View Post
Thanks.
Are you doing the simulation of the inside of the fuselage, then buoyantPimpleFoam might be the best option. If you're doing a sim of the airflow around the plane then I suppose that would work too, you probably cannot model supersonic flow though with it, not sure about other solvers, there's sonicFoam.
massive_turbulence is offline   Reply With Quote
Old   May 5, 2014, 04:42
Syed Zahid
Hi Andrew,
I think you confused TURBULENCE MODEL with SOLVER. I wanted to know about different turbulence models like SA, SST, k-epsilon, etc...
Old   May 5, 2014, 14:09
Andrew Somorjai
Hi Andrew,
See if this helps
http://www.cfd-online.com/Wiki/K-epsilon_models
You might have better responses if you explain how you want to setup your fuselage. Is it supersonic case, etc.
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 15:42
Y plus for various turbulence models taram CFX 8 December 16, 2013 11:44
Zero Equation Turbulence models stefan.gracik OpenFOAM Programming & Development 3 April 17, 2013 14:12
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
