Film flow becomes unsteady with more cells
Old   May 6, 2014, 11:34
Default Film flow becomes unsteady with more cells
MSF
MSF is on a distinguished road
I'm simulating a gravity driven film flow over an obstacle with OpenFoam1.6 (Inclination angle 10° and Re between 4 and 30). As a solver a modified version of interFoam is used, so no gravity force acts on the second phase (air). The boundary conditions are cyclic (wave length of the bottom is 2 cm).and the solver settings are taken from the damBreak tutorial, only the Courant Number is decreased to 0,1. For a Mesh consisting of 40000 cells the cases become stationary after about 1 second (see the attached picture) but if i increase the cell number to 160000 the cases are unsteady and something like a standing wave builds up. I do not think that this is physical. Any ideas why increasing the cell number leads to this unsteady behaviour?
Kind regards
Moritz
MSF is offline   Reply With Quote
Old   May 6, 2014, 12:21
Andrew Somorjai
massive_turbulence is on a distinguished road
Kind regards
Moritz
If you run the (finer mesh) simulation longer does the system come to equilibrium. I'm thinking your simulation might be more accurate and so the total energy of the system dissipates over a longer period of time?
massive_turbulence is offline   Reply With Quote
Old   May 8, 2014, 08:07
MSF
No the simulation with the finer mesh does not come to an equilibrium. For some Reynolds Numbers it seems like the simulation with the finer mesh is close to an equilibrium but then it starts to oscillate.
Old   May 9, 2014, 16:06
Andrew Somorjai
What's your deltaT and endTime?
Old   May 12, 2014, 05:00
MSF
My deltaT is 6*10^-6s and the endTime is 2.5s.
Old   May 12, 2014, 13:43
Andrew Somorjai
I was thinking your deltaT might be too large but that looks small to me.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 01:12
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Thin film flow in triangular duct Swapnil CFX 4 December 4, 2002 16:08
